How is your crank case breathing system set up? Especially you race guys.
Old Dec 29, 2001 | 09:55 AM
JM Performance's Avatar
Default How is your crank case breathing system set up? Especially you race guys.
I just wanna see how you guys have your systems set up. If its just a breather filter on the valve cover and otherwise stock.....don't bother posting. I'm looking for ideas other than that.
-Matt
Old Dec 29, 2001 | 01:48 PM
quikrpm'z's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (00SilverLS)
yeah me too.
Old Dec 29, 2001 | 02:15 PM
boomslang's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (quikrpm)
Hollowed out pcv valve and valve cover breather running to the same can. No baffles in the can. Tiny air filter on top of the can. Port in intake manifold blocked off where pcv used to go. It's open loop, and not street legal.
Old Dec 29, 2001 | 02:40 PM
Default Re: How is your crank case breathing system set up? Especially you race guys. (Inlinefour)
sounds good but how does fresh air get in the engine? don't you need to clear out the harmfull and corosive gases?
Old Dec 29, 2001 | 08:30 PM
bigTom's Avatar
moroso oil catch can or whatnot or some sort (can with big filter on top... i forgot exactly what it was used for) line from pcv to catch can.. line from valve cover to catch can (welded on fitting... stock breather blocked off)
Old Dec 29, 2001 | 08:52 PM
Guitarzann's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (Tom)
GReddy oil catch can with a breather on top
Old Dec 29, 2001 | 09:58 PM
Default Re: How is your crank case breathing system set up? Especially you race guys. (Guitarzann)
Tom, same question for you that I asked Inlinefour. Don't you need fresh air going into your crankcase?
Old Dec 30, 2001 | 07:14 PM
boomslang's Avatar
The little filter on top of the can pulls in fresh air.
Old Dec 30, 2001 | 07:45 PM
How is that possible? Whats causing the air to be pulled in?
Old Dec 30, 2001 | 10:51 PM
bigTom's Avatar
im not sure of how the breather actually works... as in when it sucks in and when it blows out... anyway u look at it... air can come back through to it... its not a pcv valve... just basically an open filter if u really think about it
Old Dec 31, 2001 | 12:26 AM
zip's Avatar
zip
Yup...same here. Open pcv setups are always venting crankcase gasses at idle and WOT.
Old Dec 31, 2001 | 01:01 AM
HX_Guy's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (zip)
What is the advantage of using a filter insated of a PCV valve with a catch can system?
Old Dec 31, 2001 | 05:18 AM
rtype11's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (HX_Guy)
pcv is a one way valve, the filter excahnges gases at ambient pressure, the pcv valve can actually vent while the filter just sits there. you really need vaccuum on a turbo motor to evacuate crankcase gases. real trick way is to hook up your breather tube to the exhaust like top fuel dragsters.
Old Dec 31, 2001 | 08:46 AM
Default Re: How is your crank case breathing system set up? Especially you race guys. (rtype11)
But still no one answered my question about needing fresh air to enter the crank case. Give me your opinion on this: "Apart from preventing pressure buildup, an important reason for crank ventilation is the extraction of acidic vapours (products of combustion), which are responsible for the majority of engine wear. If you restrict or disable your PCV system, you`ll shorten your engine life...period."
Old Dec 31, 2001 | 08:53 AM
HX_Guy's Avatar
Why do you need fresh air to enter the crankcase? Your quote did not mention that?
You need to extract the bad vapors, thats it.
Old Dec 31, 2001 | 08:55 AM
Sure it did: "an important reason for crank ventilation is the extraction of acidic vapours (products of combustion), which are responsible for the majority of engine wear"
Remeber, it may be cool for race engines to run setups like inlinefour's, but I need my car to last.
[Modified by 00SilverLS, 12:56 PM 12/31/2001]
Old Dec 31, 2001 | 11:01 AM
HX_Guy's Avatar
Again..I dont see where that quote says that fresh air needs to enter the crankcase. It says the ventelation system is to EXTRACT vapors from the crankcase...not to let new fresh air in.
Old Dec 31, 2001 | 11:13 AM
blowncivichb's Avatar
If you extract air from the crankcase, fresh air has to come in from somewhere...otherwise you'll create a vacuum.
Old Dec 31, 2001 | 03:55 PM
WykidEH's Avatar
So, where do you get a baffled oil catchcan? Who makes one? I'm wanting to get one. . . .
Old Dec 31, 2001 | 04:27 PM
Guitarzann's Avatar
Default Re: How is your crank case breathing system set up? Especially you race guys. (WykidEG6)
Thats the GReddy tank..
Old Jan 1, 2002 | 02:22 PM
can you esplain waht im looking at a little better?
greddy catch can hooked up to breather filter and valve cover? whats the pcv hooked up to?
Old Jan 1, 2002 | 02:26 PM
Arturbo's Avatar
Better than steak
25 Year Member
I'll tell you what Im looking at, a Integra with a SOHC. Wow..
art
Old Jan 1, 2002 | 02:29 PM
DIRep972's Avatar
Smarter than you
Default Re: How is your crank case breathing system set up? Especially you race guys. (Arturbo)
art
looks to me like a delsol
Old Jan 1, 2002 | 02:32 PM
Default Re: How is your crank case breathing system set up? Especially you race guys. (DIRep972)
yeah, Integra Art?? have fun last night?
Old Jan 1, 2002 | 04:26 PM
TurboSedan's Avatar
New User
LOL
