d-series mount incompatability??
Old Nov 24, 2004 | 09:38 AM
dlric's Avatar
Default d-series mount incompatability??
I'm just kind of curious if anyone has run into this before.
I'm putting a d15b7 into a 88 crx hf. the d15b7 driv side mount will not physically fit into the crx chasis mount spot. so, i grabbed a driv side mount from my 89 civic dx sedan parts car (with stock d15b2 engine) and that mount does fit, but it will not line up with the d15b7 driv side engine mount bracket.
has anyone run into this? i figure i can swap the d15b2 driv side mount bracket onto the d15b7 and use the d15b2 driv side mount. i haven't tried it yet tho. anyone know if this will work?
and also, on the 89 civic dx sedan, the rear tranny mount that bolts onto the rear crossmember appears to be held on by only 2 bolts? anyone know anything about that?
thanks guys
*Edit: I know this sounds like im being lazy, but the civic sedan is outside and its raining out so before i go out and get soaked and take the driv side bracket off, i figured i'd ask *
Old Nov 25, 2004 | 09:11 AM
dlric's Avatar
Default Re: d-series mount incompatability?? (dlric)
someone has to know this
Old Nov 25, 2004 | 02:10 PM
mr. carpenter's Avatar
use the bracket off your old motor on the driver's side mount. that's what i had to do with my z6.
Old Nov 25, 2004 | 03:21 PM
dlric's Avatar
Default Re: d-series mount incompatability?? (mr. carpenter)
cool, thanks for responding. that's what i figured i had to do.
Charlie Moua
Welding / Fabrication
Aug 27, 2011 04:36 PM
ridgeapd
Aug 21, 2009 06:21 PM
jaskuloski97sh
Jul 20, 2007 09:30 PM
dutchman5
Feb 6, 2003 12:48 AM
CIVIX
Mar 18, 2002 06:03 AM
