WHAT TRANS DO I USE........?
Old Nov 24, 2004 | 07:40 AM
nucivowner's Avatar
Default WHAT TRANS DO I USE........?
I JUST BOUGHT AN 89 CIVIC HB. I WORK AT A SALVAGE YARD SO PARTS ARE DEFINATLY AVAILABLE. MY BOSS GAVE ME A B18 ENGINE OUT OF A 89 INTEGRA. MY QUESTION IS WHAT TRANS DO I USE FOR THE SWAP? WHAT ONES FROM WHAT CARS ARE BETTER? ALSO IF ANYONE KNOWS WHERE I CAN GET LITTERATURE FOR THE SWAP, IT WOULD BE APPRECIATED.
Old Nov 24, 2004 | 08:10 AM
CRX Toad's Avatar
Default Re: WHAT TRANS DO I USE........? (nucivowner)
The best thing to do is to search all the answers are out there but you will have to dig a little to find them. Search recent and archived threads
Old Nov 24, 2004 | 08:35 AM
CRseXy's Avatar
Default Re: WHAT TRANS DO I USE........? (CRX Toad)
b blocks, get b trans. D blocks get D trans. what trans you want depends on what you want. Theres Close Ratio Trans, thats good for N\A drag racing. but **** for gas. Then theres the Wide gears witch might be good for a turbo application, found mostly on the low end hondas. SI trans are close ratio.
Old Nov 24, 2004 | 08:40 AM
rjay8604's Avatar
Default Re: WHAT TRANS DO I USE........? (pogiTSI)
Well if its out of an 89 integra it should be a D16A1, but i'm guessing its out of a 90 teg with the b18a. Get a b16 trans, or LS trans of course.
Old Nov 24, 2004 | 09:11 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">Then theres the Wide gears witch might be good for a turbo application.</TD></TR></TABLE>
Please explain this...i hope no one takes this info as right.
Vince
Old Nov 24, 2004 | 09:52 AM
getnasty's Avatar
Default Re: WHAT TRANS DO I USE........? (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">
Vince</TD></TR></TABLE>
duh you stay in boost longer!!! lol thats what they always say...
Old Nov 24, 2004 | 11:08 AM
limpy's Avatar
Default Re: WHAT TRANS DO I USE........? (bottle fed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">Well if its out of an 89 integra it should be a D16A1, but i'm guessing its out of a 90 teg with the b18a. Get a b16 trans, or LS trans of course. </TD></TR></TABLE>
haha... that is what i was thinking.
Old Nov 24, 2004 | 11:19 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">
duh you stay in boost longer!!! lol thats what they always say...</TD></TR></TABLE>
I really hope you people are being sarcastic...do the math.
Do i really have to explain?
Old Nov 24, 2004 | 11:49 AM
LSvtec03's Avatar
Do i really have to explain? </TD></TR></TABLE>
i sure hope not. i hate when people dont get that longer gears are not better...
anyway, find out if your boss gave you a b18a1 from a 90 integra or a d16a1 from an 89 integra and go from there.
Old Nov 26, 2004 | 03:47 AM
SwissChEz82's Avatar
Default Re: WHAT TRANS DO I USE........? (LSvtec03)
Check the stamp on the block to find out what engie it is. The D16a1 won't fit your HB but with a mount kit the B18a will. The easiest solution with a B18a is find you good cable tranny from the same 90-93 integra and go from there. If it turns out to be a D16a1 then you're better of getting a ZC.
VR4ever
Transmission & Drivetrain
Apr 10, 2012 11:52 PM
burtonzt
Honda Civic (2001 - 2005)
Feb 8, 2008 11:03 PM
BLUE EH3
Feb 6, 2007 01:50 PM
