Dry starting on the R mota!?
Old Nov 24, 2004 | 07:28 AM
jdmkevin's Avatar
Default Dry starting on the R mota!?
Alright...so right now I'm running Mobil 1 5w-30 and I have noticed that when the car sits for a while (even just overnight) on startup it sounds like it's getting no oil in the valvetrain for a couple of seconds, and then it goes away...this is dry starting correct? Anyway, I'm thinking since I installed the exedy flywheel it's been doing it cause the motor revs up more on startup...is this a logical explanation?
-I'm not real comfortable with putting in some additives...especially after reading this... http://www.bobistheoilguy.com/...s.htm
So which weight oil should I run? I've seen the Mobil 1 15w-50 high performance stuff at the parts store, does anyone have any info on this?
THanks guys
Happy THanksgiving...almost
Old Nov 24, 2004 | 07:39 AM
Bbasso's Avatar
Default Re: Dry starting on the R mota!? (jdmkevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkevin &raquo;</TD></TR><TR><TD CLASS="quote"> on start up it sounds like it's getting no oil in the valvetrain for a couple of seconds, and then it goes away...this is dry starting correct? </TD></TR></TABLE>
Most cars do that, if your really concerned you can get a oil primer setup but that's a little much.
Old Nov 24, 2004 | 08:26 AM
mikehonda's Avatar
Mobil 5w-30 is to thin a oil in my expierence/opinion. You'll prolly notice also that it just disappears. I recommend Castrol Synthetic 10w-30 to all my customers. I've never had an oiling prolum since.
mikehonda: who tried lots of diffrent oils
Old Nov 24, 2004 | 10:13 AM
Chris93Si's Avatar
Default Re: Dry starting on the R mota!? (mikehonda)
What about Mobil1 10w-30? Have you tried that? You use 10w-30 in all conditions?
&lt; Who's thinking it'd be nice to use 10w-30 cause then he wouldn't have to buy two different weights for the Cibic/Integra and the CRV.
Old Nov 24, 2004 | 10:16 AM
jond's Avatar
Default Re: Dry starting on the R mota!? (Chris93Si)
5W30 should theoritically pump faster than 10w30 or 10w50
Old Nov 24, 2004 | 10:29 AM
Chris93Si's Avatar
Default Re: Dry starting on the R mota!? (jond)
On the flipside, 10w30 might have a better chance of staying up in the motor when it's cools down.
Old Nov 24, 2004 | 10:33 AM
cjames235's Avatar
i run castrol gtx 5w30 and have never had any sounds like that.... guess its cus its not synthetic or somethin
1slow02
Oct 31, 2008 05:46 AM
invisible
21
Dec 27, 2006 08:27 AM
fafsa
Dec 22, 2004 02:46 PM
ahobbs
Oct 23, 2003 05:48 AM
fsck3r
Aug 8, 2003 03:47 PM
