testing duty cycle for stock injectors
Old Nov 24, 2004 | 07:26 AM
cxVtecC1's Avatar
Default testing duty cycle for stock injectors
is there a way for me to test my injectors to find out if they are working properly, if so how?Im rebuiling a motor and want to make sure that my old injectors are still ok ,ive heard some bad things about just dumping in feul injector cleaner. Is there a way for me to up the duty cycle of an injector if i find one is squirting incorrectly? Any help on this topic will be appreciated...
Old Nov 24, 2004 | 08:42 AM
EE_Chris's Avatar
Default Re: testing duty cycle for stock injectors (cxVtecC1)
The easiest thing to do is send them off to RC or Cruizin' Performance for a thorough flow test and cleaning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxVtecC1 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way for me to up the duty cycle of an injector if i find one is squirting incorrectly? Any help on this topic will be appreciated...</TD></TR></TABLE>
Nope.
And if it was squirting incorrectly, fixing the problem correctly should be your primary concern - not finding a band-aid to cover it up.
Old Nov 26, 2004 | 04:44 PM
oldguy03's Avatar
Do a search on the G2IC.com site. There was a guy on there that built a little jig for soaking the injectors in solvent without ruining them. Don't screw around with trying to make them pulse. The injector pulse is very short and can't be done quickly enough by hand. The same guy built a switching mechanisme to test the funtion of the injector. As for duty cycle, if they work, they work. The duty cycle is a function of their flow capability usually measured at 80% capacity. There are formulas for determining that if you need it. I think I have one in a Summit Racing catalogue. You don't say why you are worried about duty cycle. Its only a problem if your fuel flow requirements are going to increase significantly.
Old Nov 26, 2004 | 05:30 PM
cxVtecC1's Avatar
Default Re: (oldguy03)
im putting a new motor together and plan to run a mild cam/head setup i was just making sure that these old injectors would still be working properly maybe i shouldn't have said duty cycle but i think i got my answert though ..thanks
Rikaro
Aug 25, 2008 10:40 PM
champLSinteg
Oct 26, 2007 07:02 AM
champLSinteg
Oct 24, 2007 07:44 AM
huge230
Oct 1, 2005 09:39 PM
wrestler121
Oct 15, 2003 12:31 AM
