is aftermarket oil pump gear???
Old Nov 24, 2004 | 06:29 AM
boostedeg22's Avatar
Default is aftermarket oil pump gear???
i'm ready to install my new setup.tryed search but could not find anything.i plan to run up to 24psi.bottom line do i need to buy a aftermarket gear or would itr gear be o.k. input greatly needed.
Old Nov 24, 2004 | 06:30 AM
Adi Radoncic's Avatar
On Fire!
Default Re: is aftermarket oil pump gear??? (boostedeg22)
itr is all good!!
just make sure your bottom end is balanced and a fluidamper crank pully wouldn't hurt to have either..
Old Nov 24, 2004 | 06:31 AM
B18C1CYA's Avatar
stock one will be fine , just make shure you use a good dampener , do not use the n1 crank pully,
Old Nov 24, 2004 | 08:08 AM
Default Re: is aftermarket oil pump gear??? (B18C1CYA)
thanks for the replys
q16racer
17
Oct 31, 2010 03:09 PM
pleej
Sep 9, 2009 10:56 PM
See Are X
Feb 11, 2005 09:13 AM
d.str0y
Dec 7, 2004 02:48 PM
See Are X
Nov 12, 2003 04:14 AM
