good epoxy
Old Nov 23, 2004 | 11:00 PM
drunknbass's Avatar
Default good epoxy
i need to attach my throttle bodies to the runners and i dont really want to use hose clamps cause they look like crap. and the rest of my itb setup is done really well, i thought about having the tb's welded to the runners but the heat would distort the shape and **** them up.. so i figured a good epoxy will work.. there is barely any weight on the tb at that point, just the weight of the tb itself and the stacks. so i just need something good to join them
Old Nov 23, 2004 | 11:39 PM
drunknbass's Avatar
Default Re: good epoxy (drunknbass)
will this work?
http://www.use-enco.com/CGI/IN...49002
or this?
http://www.use-enco.com/CGI/IN...LMK32
Old Nov 24, 2004 | 07:28 AM
D-cell's Avatar
DEVCON is great. FUSOR or any equivalent body panel adhesive will work as well. Check around at your local body shop supply store, they'll have one or more of them.
Old Nov 24, 2004 | 11:12 AM
Tad's Avatar
Tad
Default Re: good epoxy (D-cell)
JB weld man,
stuff is tuff.
you can get it at most autoparts stores,
DIY honda guys use it alot,
homemadeturbo projects use it alot.
Old Nov 24, 2004 | 12:04 PM
drunknbass's Avatar
Default Re: good epoxy (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">JB weld man,
stuff is tuff.
homemadeturbo projects use it alot.</TD></TR></TABLE>
na i know what jb weld is.. i was looking for something better.
Old Nov 24, 2004 | 01:06 PM
RCautoworks's Avatar
Find these clamps, these are Honda OEM clamps used on cbr's
Old Nov 24, 2004 | 01:18 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">
na i know what jb weld is.. i was looking for something better. </TD></TR></TABLE>
hehe, ok well i tried anyways
Old Nov 24, 2004 | 01:23 PM
nonsense's Avatar
Default Re: good epoxy (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Find these clamps, these are Honda OEM clamps used on cbr's</TD></TR></TABLE>
they should isolate the ITB's from too much vibration too. Any tome you can do that it's a good thing. I think that an epoxy would eventually crack too.
Old Nov 24, 2004 | 01:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: good epoxy (nonsense)
if you do decide to go with the clamps like posted above, let me know. I'm pretty buddy buddy with the local honda/suzuki/yamaha/kawasaki dealer.
Old Nov 24, 2004 | 01:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, usually OEM parts that Honda has designed and put some time into are good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">if you do decide to go with the clamps like posted above, let me know. I'm pretty buddy buddy with the local honda/suzuki/yamaha/kawasaki dealer.</TD></TR></TABLE>
I'm interested in atleast 4, get back to me with the prices on them.
Old Nov 24, 2004 | 01:39 PM
wantboost's Avatar
Who is Mr Robot?
I;ll get back to you as soon as i can. It might be the beginning of next week as i'm not at my dads.
Old Nov 24, 2004 | 05:30 PM
user 9782082308's Avatar
Default Re: good epoxy (wantboost)
I can vouch for Fusor. Its used as "structural" adhesive for body panels.
Old Nov 24, 2004 | 08:53 PM
crx12's Avatar
Default Re: good epoxy (racerx)
Depending on the heat they see you might have a problem with the epoxy cracking due to the difference in CTE. JB Weld actually wouldn't be that bad of an idea since it is an epoxy with metal in it and it takes heat well. An adhesive you might try is Loctite Hysol 9430. It is used to bond composite bike frames to their metal lugs. You can get it at http://www.rshughes.com along with many other adhesives.
Old Nov 25, 2004 | 09:09 AM
StyleTEG's Avatar
Default Re: good epoxy (crx12)
I used some 3M liquid epoxy my friend got from his welding school. He says the 3M reps came by, and said they tested it on a car and it lasted longer than some of the welds.
I wish I could find the name of it off hand, but its not listed on the 3M website.
I also fiberglassed the inside of the manifold portion, one to smooth out the inside of the runners and also I figure it will aid somewhat in strength.
So far so good, it seems to be pretty damn strong and heat hasn't effected it.
Old Nov 25, 2004 | 10:22 AM
eHoward's Avatar
Not sure about heat distortion, but I would try this stuff before JB.
http://products3.3m.com/catalo..._html
9seccivicsi
Jul 17, 2004 08:27 AM
iwhichisme
Jan 12, 2003 04:19 PM
