RHD Starting problems, Injectors not firing
Old Nov 23, 2004 | 10:13 PM
atli126's Avatar
Default RHD Starting problems, Injectors not firing
my injectors are not firing , we are getting fire and the timing is right,
i know that im getting power to them they are not firing tho, im really thinking its the wiring like grounds
so far i have searched h-t.com and found this,
https://honda-tech.com/zerothread?id=1056115
https://honda-tech.com/zerothread?id=1053088
Old Nov 24, 2004 | 07:02 AM
atli126's Avatar
Default Re: RHD Starting problems, Injectors not firing (atli126)
ttt
Old Nov 24, 2004 | 09:02 AM
E36 Guy's Avatar
Did you do a rhd conversion on it or what? whats the reason you put RHD in your title? Are you saying you are having this problem after you did the conversion?
Old Nov 24, 2004 | 12:05 PM
atli126's Avatar
Default Re: RHD Starting problems, Injectors not firing (b18c3)
sorry its a rhd car, i just didnt think about it, my ls swap that is in it, will not start, and i know that i am not getting my injectors to fire
thanks
bret
Old Nov 24, 2004 | 12:44 PM
sammysnakes's Avatar
is your fuel pressure correct? maybe they're firing, but the fuel isn't pressurized enough to atomize?
Old Nov 24, 2004 | 12:48 PM
atli126's Avatar
Default Re: RHD Starting problems, Injectors not firing (chainsaw)
yup fuel pressure is up to spec
Old Nov 24, 2004 | 04:26 PM
krazie1's Avatar
BANNED
so they are getting signal???
and the resistor box is working or plugged up
the main relay good??
just something to check
Also fuse u never know.....
Old Nov 24, 2004 | 05:54 PM
atli126's Avatar
Default Re: RHD Starting problems, Injectors not firing (krazie1)
keep em coming i know all this stuff so far but it never hurts to hear opinions
thanks to all
Old Nov 24, 2004 | 06:02 PM
DrVtec99's Avatar
pour some gas on the motor and add spark
i think 502 has u covered.
Old Nov 24, 2004 | 06:13 PM
atli126's Avatar
Default Re: (DrVtec99)
yup i think so too, free bump for 502ss.net
Old Nov 24, 2004 | 09:32 PM
boostn420's Avatar
Default Re: (atli126)
if the motor was sitting for a while the injectors could be clogged and just not opening. You should lift the rail off the mainfold and check their spray pattern. Try cleaning them or giving them a direct power and ground with a couple of wires and try to get them to fire "manually"
Old Nov 25, 2004 | 03:54 PM
atli126's Avatar
Default Re: (boostn420)
thanks ive got a ton of **** to try tomarrow
happy turkey day to all
thanks for the help
Old Nov 26, 2004 | 02:48 PM
atli126's Avatar
<U>
ITS STARTED AND RUNS GREAT !!!!!!!!!!!!!!!!!!!111
</U>
The problem's were
the ground on the thermostat, it looked good but we cleaned it up and it fired right up and then stumbled again,
that was when we found out that we were missing the map sensor , bc the **** that did my swap in my old ride, had not mounted the map or the other one that sits right next to it, and they were just dangling, so we hooked those up, and it ran good but then stubled and fell and died again
then we just need the hose that for the brake booster and it ran, and ran , and it runs great.
Should now be done by my bday dec 6th, bc we still have some stuff to put back together,
thanks for all who helped , i have found 502 to be the most helpful and resourceful as far as the people and a huge thanks to honda-tech.com, they really are great places
Bret
LightningTeg
Jun 6, 2009 05:43 PM
Hi-Tech Honda Girl
Jan 1, 2007 09:17 PM
CLE
Jul 13, 2006 02:25 PM
EGHatchy
Jul 14, 2002 11:25 AM
