A few questions in one
PR3 ecus usually come with 1st gen B16A's and come from Integra XSi's or Civic/CRX SiR's. There are also OBD1 PR3's too. The YS1 tranny came in 92-93 USDM Integra GSR's. There is also a JDM version with an optional LSD. I'm not too clear on what car came with those YS1's...I'm thinking Integra XSi's did, not too sure though. All D and B series injectors are 240cc/min.
well i know that i can use my stock wiring harness for the ls/vtec...but i was wondering if i am running a 98 integra block and a 89 crx si jdm head with a pr3 ecu and i wanted to just buy the wiring harness for that set-up what wiring harness would i order and from what car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zatzy »</TD></TR><TR><TD CLASS="quote">well i know that i can use my stock wiring harness for the ls/vtec...but i was wondering if i am running a 98 integra block and a 89 crx si jdm head with a pr3 ecu and i wanted to just buy the wiring harness for that set-up what wiring harness would i order and from what car? </TD></TR></TABLE>
Use the existing wiring harness that is in your car, and modify it as necessary. Putting a new harness in is a PITA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bernie'sb16crx »</TD></TR><TR><TD CLASS="quote">so does the usdm 92-93 gsr ys1 have an lsd?</TD></TR></TABLE>
No it does not come with a factory LSD.
I would like to point out that the YS1 is also the same code used for 90-93 Teg LS trannies. This is important to know this because the USDM YS1 found in the 92-93 GSR has short gearing more suited for NA. The USDM YS1 found in the 90-93 Teg LS has longer gearing which is more suited for FI.
also if i wanted to go out and buy some parts for my ls/vtec....ie, fuel rail, throttle body....what would be the best car to tell them i need to parts from. i only ask cause its a jdm crx si head.
slammedef06
Dec 29, 2005 10:42 AM
Steve91
May 25, 2005 11:19 AM
