how can i tell if o2 sensor is working/wired up correctly?
Old Nov 23, 2004 | 09:01 PM
so simple's Avatar
Default how can i tell if o2 sensor is working/wired up correctly?
well ive been failing smog a lot and i found out that my o2 sensor was not hooked up. for some reason the o2 sensor plug was female when its supposed to be male. so i ordered a new ngk o2 sensor. and i didnt have time to install it so i just spliced the new male plug to the old o2 sensor. i plugged the old female and new male plug together to match up wire colors. the old was like blk, blk, grn, wht and the new was wht, wht, blk, gry. i wired it up blk/wht, blk/wht, grn/blk, wht/gry as that was how the plugs attached to each other. when i have time ill splice it back into the new o2 sensor and install that, but just curious how can i tell if it even works? will i get a different idle? better performance? throttle response,etc? thanks, sorry if its a stupid q
Old Nov 23, 2004 | 10:21 PM
IVI's Avatar
IVI
Default Re: how can i tell if o2 sensor is working/wired up correctly? (simpleaznx)
your cel will not be giving you a code for the oxygen sensor.
Old Nov 23, 2004 | 10:27 PM
so simple's Avatar
its weird, when the o2 sensor wasnt hooked up i had no cel, it only showed a code when i jumped the connector it threw code 1/o2 sensor. is that normal? now with it hooked up it still doesnt show a code but i didnt jump it yet
Modified by simpleaznx at 7:44 AM 11/24/2004
Old Nov 24, 2004 | 07:24 AM
IVI's Avatar
IVI
Default Re: (simpleaznx)
thats pretty weird, im almost certain it should show you a code.
when mine was disconnected like yours is i had a couple other problems with the car so it was illuminated.
but thats what code 1 is referring to.
disconnect the battery for 5-10 mins.
Old Nov 24, 2004 | 08:38 AM
Rory Breaker's Avatar
Your wiring is wrong BTW if I remember right. Green (harness)--->Grey (new sensor) and white (harness)---->black (new sensor). The other 2 are correct.
Old Nov 24, 2004 | 08:41 AM
branch's Avatar
Obey.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simpleaznx &raquo;</TD></TR><TR><TD CLASS="quote">and i didnt have time to install it so i just spliced the new male plug to the old o2 sensor. </TD></TR></TABLE>
There's your problem.
Old Nov 24, 2004 | 10:54 AM
so simple's Avatar
if i switch up the wiring how can i tell if it works though?
importdreamer
May 26, 2007 06:58 PM
EJ8chu
Jan 20, 2007 12:53 PM
cu3tip
Oct 18, 2004 08:26 PM
97civicdx
Sep 3, 2003 12:49 PM
