air/fuel ratio gauge stuck! on rich!
Old Nov 23, 2004 | 08:09 PM
93FastLs's Avatar
Default air/fuel ratio gauge stuck! on rich!
94 honda vx with c1 swap , i just recently installed an air/fuel ratio gauge. i had a shop do it for me. but for some reason the gauge is stuck on green.! im guessen it's stuck on burning rich! cause my exhaust fumes are black when i shift and when i normally drive..! where is the air/fuel ratio gauge suppose to be spliced into.?
Old Nov 23, 2004 | 09:00 PM
PrettyLude's Avatar
white wire on o2 sensor
Old Nov 23, 2004 | 09:13 PM
lanojp1's Avatar
im goin to guess ur OBD2, which would be the all white wire...
Old Nov 23, 2004 | 09:32 PM
93FastLs's Avatar
Default Re: air/fuel ratio gauge stuck! on rich! (93FastLs)
nope it's an obd1 they said they spliced into everywire in the o2 sensor and my gauge is still hitten the green. it doesnt move when i drive or at idle it just stays green..
Old Nov 23, 2004 | 09:39 PM
PrettyLude's Avatar
if its staying on green all the time i don't think you hit the right wire, it supposed to be the white wire on the o2, and if you did put it on the white wire, sometimes it takes a little while to heat up the o2 sensor to properly work on the gauge
Old Nov 24, 2004 | 07:12 AM
Burke's Avatar
Banned
Default Re: (PrettyLude)
it should go full lean on decel
Old Nov 24, 2004 | 07:24 AM
lanojp1's Avatar
check the article on teamintegra.net for the OBD1 version of the install, i think its the white/red wire..
Old Nov 25, 2004 | 09:55 AM
93FastLs's Avatar
could it be that the o2 sensor is bad ? and the gauge stays green ALL the time never changes...
Old Nov 25, 2004 | 10:32 AM
King-Kong's Avatar
what type of gauge is it, autometer?, I wouldnt trust anything except fjo wideband sending unit and o2 sensor. the vx's have the 5 wire right? if so, thats the one i run with my fjo. My autometer a/f gauge always showed me rich while in boost and when i put it on the dyno and used a wideband i was dead lean and i was using a brand new o2 sensor right from honda with the a/f gauge. just my $.02. find someoe locally with a wideband and pull some street runs to actually see where you are at.
chriscool888
Mar 29, 2012 09:08 AM
95integraLS003
Sep 10, 2005 04:22 PM
blackeg
Mar 19, 2005 05:16 PM
tunerhonda99
Jul 25, 2004 10:54 PM
DLB1994
Dec 13, 2003 07:25 PM
