Will these axles fit?
Old Nov 23, 2004 | 07:43 PM
beeroh's Avatar
Default Will these axles fit?
I have a 91 HF , I bought some front axles from an 88 HF, will they fit?
Old Nov 23, 2004 | 07:49 PM
jlicrx's Avatar
Default Re: Will these axles fit? (beeroh)
yes
Old Nov 23, 2004 | 07:55 PM
beeroh's Avatar
Default Re: Will these axles fit? (jlicrx)
sweeeeeeeeeeeeeet
Old Nov 23, 2004 | 08:45 PM
EFHondaRue's Avatar
Actually you might want to double check because if i remember correctly the splines from an 88-89 hub are different from the 90-91 hub. So they might not fit. But again I'm not 100% sure. Anybody else agree?
Old Nov 23, 2004 | 08:51 PM
Stefndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beeroh &raquo;</TD></TR><TR><TD CLASS="quote">sweeeeeeeeeeeeeet</TD></TR></TABLE>
Old Nov 23, 2004 | 08:52 PM
beeroh's Avatar
Default Re: Will these axles fit? (EFHondaRue)
Someone please reply
Old Nov 23, 2004 | 08:58 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFHondaRue &raquo;</TD></TR><TR><TD CLASS="quote">Actually you might want to double check because if i remember correctly the splines from an 88-89 hub are different from the 90-91 hub. So they might not fit. But again I'm not 100% sure. Anybody else agree?</TD></TR></TABLE>
The HF and STD hatch hubs are smaller. CRX DX and Si along with Civic Si have the larger hubs for b-series axles. If you swap HF axles for HF axles, you should be fine. I've never heard of the hubs being different from year to year, only model to model.
Old Nov 23, 2004 | 08:59 PM
mr. carpenter's Avatar
Default Re: Will these axles fit? (Mr_CRX)
this is correct.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
The HF and STD hatch hubs are smaller. CRX DX and Si along with Civic Si have the larger hubs for b-series axles. If you swap HF axles for HF axles, you should be fine. I've never heard of the hubs being different from year to year, only model to model.</TD></TR></TABLE>
Old Nov 23, 2004 | 09:02 PM
beeroh's Avatar
Default Re: Will these axles fit? (mr. carpenter)
I just did a part comparison on majestic hondas site for driveshaft parts and they have different part numbers for the Right axle, everything else is the same?
Old Nov 24, 2004 | 03:41 AM
Garrett's Avatar
I confirm this
Old Nov 24, 2004 | 06:31 AM
EFHondaRue's Avatar
That sounds correct.......I knew it was something like that but I just couldn't remeber exactly what it was. Thanks for correcting me.
RCautoworks
10
Aug 28, 2005 09:24 AM
SiMateoAko
Aug 19, 2005 01:37 PM
superbeastcrx
Oct 28, 2004 10:44 AM
sauchi55
Mar 14, 2004 09:47 PM
pdiddyparsons
Mar 19, 2003 09:34 PM
