uh-ohh...hahah help on broken....
well i dont exactly understand what you mean by the side 10 mm bolts, i believe your head bolts should be about 14mm or so. what side bolts are you referring to?
and it could be possible for it to vibrate loose from the threads and interfere with moving engine parts if it is indeed located in the head.
do you mean the valve cover bolts? i know there is something for removing a bolt thats had its head busted off, i cant recall the name tho, i think its like a helicoil or something, or is that what you put in the hole if you were to drill the bolt out thus losing the threading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F »</TD></TR><TR><TD CLASS="quote">do you mean the valve cover bolts? i know there is something for removing a bolt thats had its head busted off, i cant recall the name tho, i think its like a helicoil or something, or is that what you put in the hole if you were to drill the bolt out thus losing the threading. </TD></TR></TABLE>
easy out ? (tm)
easy out ? (tm)
Joshgb
Mar 26, 2018 01:32 PM
Cuong-nutz
Apr 13, 2005 09:39 PM
VXpride
Jul 31, 2003 08:53 AM
