SL3 transmission code, what trans is it?
Old Nov 23, 2004 | 06:52 PM
4gZC's Avatar
Default SL3 transmission code, what trans is it?
i bought this transmission from a shop near my house saying that it was a crx si trans. but i compared my trans, which has SL3-5110759 printed on it, and my friends, which has L3 - XXXXX. and his tag is in a totally different spot. it doesnt seem to want to go into fifth gear either, which makes me believe that this is a 4 speed tranny. any help would be apreciated, thanks
Old Nov 23, 2004 | 07:56 PM
mr. carpenter's Avatar
Default Re: SL3 transmission code, what trans is it? (4gZC)
if it won't go into fifth then it's probably an std trans. search trans. codes in this forum only. i know there are a couple of threads that describe the different stamps on the casing above the pass. side axle that denote which tranny case it is, mind you internals could be swapped.
Old Nov 23, 2004 | 07:57 PM
jlicrx's Avatar
most SL3's are from 91 DX - tag is on top instead of on front by engine designation - no way to tell if it is 4 speed by looking at outside - if it won't shift to fifth, it may not have fifth
Old Nov 23, 2004 | 07:59 PM
Default Re: SL3 transmission code, what trans is it? (jlicrx)
read through this thread.
https://honda-tech.com/zerothread?id=98181
Old Feb 10, 2015 | 04:32 PM
Manny Lopez's Avatar
I got a L3 trans, what axle do I need I got the one that came inmy civic but they to small for the trans.....
Mark Benedict
Dec 17, 2017 07:24 PM
GPC91
Aug 4, 2012 11:18 AM
AZ90DATEG
Feb 25, 2007 03:14 PM
FMIDRC Racer
Feb 2, 2005 05:32 PM
hOndafienD 04
Nov 2, 2004 08:06 AM
