vafc alternatives?
I prefer the field unit because it has a voltage limiter to keep you from
increasing the map voltage over what the max should be, in this case 2.8V.
The Apex does not do this.
If you go over the voltage, it will throw a code as the ECU thinks its seeing boost.
I still prefer the VAFC over the fields. It shows the engine's vacuum, throttle position, rpm, etc. It is kinda flashy though...which can be a bad thing.
You can find the VAFC for $300 shipped online.
Jackson Racing makes one
http://www.jacksonracing.com/pages/partshonda.html
[Modified by Grandprix, 2:46 PM 12/29/2001]
ShakesTheKlown
May 10, 2004 03:16 PM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
