Question about the Mini-me swap, its been unanswered...
I have a D16a6 block, putting a ZC SOHC VTEC head on it, now can i use my stock dizzy or do i need a ZC dizzy? and someone told me i dont need to get a diff ecu just bypass it with A4 and D6?
jesus stop bumping youve bumped 6 times in 25 minutes...the ef board dosent move that fast....be patient dude...and sorry I dont know your question
you have to dremal out one of the holes on the A6 dizzy... maybe if you searched you could find somthing (hint: search under arcived)
You want to run a d15b head on an a6 block.
That is the exact same thing as running a z6 head on an a6 block. D15b is obd1, the a6 is obd0. So in order to stay obd0 you need an rpm activated switch to activate vtec, and you need to dremel out the top mounting hole on the a6 dizzy to bolt on the d15b head. If you want to use the d15b ecu(not a ******* clue what that is) or a p28. Your going to use your d15b or z6 dizzy. After you have that whole ecu and dizzy thing figured out, you can jump into the fun that is converting to obd1.
Gist of the story, SEARCH, but search for a z6/a6 mini me
