whats up with this ecu p28-a02???????
alright i found this ecu at a juckyard and got it for 80bucks
but when i went to chip it follwing kebblers write up i noticed were he said there sould be a spot to install a chip but on mine there arleady was one installed.....it has to be a factory job the spots are to perfect on the bac.. but does this chip have anything to do with the a02? part i searched and found nothing useful please help
didnt no how to post pics but i have some if needed
but when i went to chip it follwing kebblers write up i noticed were he said there sould be a spot to install a chip but on mine there arleady was one installed.....it has to be a factory job the spots are to perfect on the bac.. but does this chip have anything to do with the a02? part i searched and found nothing useful please help didnt no how to post pics but i have some if needed
p28 is the code of the ecu
its a p28 ecu
all ecu's are chipped from the factory, usually the chip is removed and replaced with a socket so you can remove and install multiple chips without desoldering the chip out of the board.
so right now you have a p28 ecu (92-95 sohc civic vtec)
its a p28 ecu
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
PM8 : 88-91 CRX HF
cool thats what i thought and i found out that the a02 is just the version number so this ecu is verion number 2 whatever that means, thanks for the ecu list
guess i ll start chipping away
Frost7177
Feb 20, 2009 03:44 PM
