airbox hole diameter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz »</TD></TR><TR><TD CLASS="quote">[img]whats the diameter of the hole on the bottom of the airbox?</TD></TR></TABLE>
There is a rubber gasket that seals the hole. With the rubber seal, a 3" pipe will fit perfectly. Without the rubber gasket it would be right around 4".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ »</TD></TR><TR><TD CLASS="quote">
There is a rubber gasket that seals the hole. With the rubber seal, a 3" pipe will fit perfectly. Without the rubber gasket it would be right around 4".</TD></TR></TABLE>
thanks for the reply bsq! glad to see you are still around. your DIY website was always a help
