how to tighten throttle cable on b16a2
Old Nov 23, 2004 | 01:58 PM
Declectic's Avatar
Default how to tighten throttle cable on b16a2
my throttle cable is loose, how do i tighten it? i search but i guess i'm using the right words??
there are 2 nuts, seperated by a plate, which why do i go with them??
Old Nov 23, 2004 | 02:02 PM
Spade's Avatar
Default Re: how to tighten throttle cable on b16a2 (SeanJohn1802)
loosen the outside one to loosen the two nuts from grabbing the tb bracket.
Once you do that spin the end nut closer to the end to tighten it. DO NOT over tighten the cable as it may snap when you press on the pedal.
Once you have it tighted properly.....about a 1/4 of movement up/down.
tighten the first nut back to the braket to hold it in place.
Old Nov 23, 2004 | 02:10 PM
Declectic's Avatar
Default Re: how to tighten throttle cable on b16a2 (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">loosen the outside one to loosen the two nuts from grabbing the tb bracket.
tighten the first nut back to the braket to hold it in place.</TD></TR></TABLE>
i thinki got it.. thanks bro . .
emm.. any pics perhaps? and when u say.. move it closer.. standing at a point looking at the engine bay from the front bumper.. move it closer to the left (towards the passenger fender) or to the right (towards the driver fender)
lohatch's Avatar
or in simpler terms. take 2 wrenchs, place one on each nut, loosen left nut, tighten right nut until prefered throttle cable tightness is achieved, then tighten left nut back on bracket. hold the right nut with your wrench while doing this, make sure they are both tight on the bracket. now that your have successfully adjusted your nuts you can take a break
dayaftertomorrow
Mar 18, 2005 02:15 AM
return_2020
Dec 8, 2004 02:38 PM
Traction
10
Aug 24, 2004 01:36 PM
D17 MoNsTeR
May 2, 2003 08:34 AM
