85mm x 86mm b16a; powerful and reliable?
Old Nov 23, 2004 | 12:04 PM
slickstck's Avatar
Default 85mm x 86mm b16a; powerful and reliable?
i am currently having an engine built for my 93 si hatchback. b16 block bored 40 over and stroked 5mm via machining a ls crank, je sleeves, je pistons 9.0:1, crower rods, clevite bearings, arp block guard, head studs, cometic head gasket. it will be tuned usuing hondata with 600cc injectors, hopefully up to 18psi. i was always under the impression that boring and stroking was not as reliable as just building for turbo. basically what i am asking is will this set up make me 380whp with a big t3/t4 and will it last a good while if treated right?
Old Nov 23, 2004 | 12:09 PM
PM-Performance's Avatar
Default Re: 85mm x 86mm b16a; powerful and reliable? (slickstck)
you can do that easily on stock bore. Dont waste the time of overboring, esp that much and for that power goal.
oresama
13
May 23, 2012 12:30 PM
Mr.Bourbon
May 7, 2012 07:47 PM
x_heu
Mar 15, 2011 04:51 PM
teamsoy1320
Jun 29, 2006 04:35 PM
turbodohcsi
Apr 14, 2005 01:02 PM
