GSR TB & Type R throttle cable
Before you all flame yes I have searched. Will the Type R throttle Cable fit on the Gsr TB? I haven't found a thred yet that said it would. IF you haven't figured it out I've got a Skunk2 mani!
As long as you use a B16 or ITR throttle pulley and ITR throttle cable bracket, it'll work out fine with the ITR throttle cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">As long as you use a B16 or ITR throttle pulley and ITR throttle cable bracket, it'll work out fine with the ITR throttle cable.</TD></TR></TABLE>
I set up a customer's skunk2 manifold equipped GSR with an LS pulley to make it work
thanks for all of the input, I'm just going to run all ITR parts from the pulley to the bracket. that way I know it will all work together
Eghatchgsr8
Oct 11, 2014 03:09 PM
