Important information about K series sleeves
Old Nov 23, 2004 | 09:40 AM
Nikos's Avatar
Default Important information about K series sleeves
Till today, I though that k series sleeves were made from the same material as the b series ones... I was wrong. A member of my site, posted this info that I think should be passed along
http://www.saffil.com/pdfs/aut...p.pdf
Please comment.
thanks,
Nikos
Old Nov 23, 2004 | 10:46 AM
Tactic$'s Avatar
Default Re: Important information about K series sleeves (Nikos)
cool stuff....
Old Nov 23, 2004 | 04:51 PM
earl's Avatar
I did not see anywhere in the report where they mentioned the K Series. They did mention the S2000 (F20C). What am I missing?
Old Nov 23, 2004 | 05:58 PM
DefiantGSR's Avatar
Default Re: Important information about K series sleeves (earl)
s2000 was mentioned on the first page..
Old Nov 23, 2004 | 07:05 PM
Nikos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I did not see anywhere in the report where they mentioned the K Series. They did mention the S2000 (F20C). What am I missing?</TD></TR></TABLE>
They do mention about the new accord (k24a) on the right column....
We need to have this confirmed by Golden Eagle or someone in the sleeve industry but it seems like K series blocks are NOT iron, they are MMC. Really hard to bore that material..they are hard as nails, hence why people pull them out and replace them with iron (read much cheaper/easier)
MMC" or metal matrix which incorporate amounts of silicon and carbide to improve or permit piston ring abrasion resistance however, machining of this type of material is difficult and expensive.
BAR’s engine partner Honda has produced an uprated power unit for its home grand prix at Suzuka this weekend.
The latest development of the RA004E V10 is believed to develop a staggering 960 HP, making it the most powerful engine in Formula 1. It uses advanced metal matrix composite (MMC) components to increase revs and consequently horsepower.
Honda’s F1 project leader Takeo Kiuchi believes the power output of F1 cars could exceed the magic 1,000 HP threshold next season.
“It’s within reach,” he told Autosport. “That level will not be easy - there are several difficulties to conquer first. But it could be possible.”
Comments?
Old Nov 23, 2004 | 09:07 PM
PrettyLude's Avatar
good info
Old Nov 23, 2004 | 10:30 PM
earl's Avatar
Default Re: (PrettyLude)
Let me go out on a limb and say the K sleeves are not matrix metal. The reason I say this is that matrix metal blocks require a special piston also.
Several aftermarket piston manufacturers, CP for one, offer aftermarket pistons for the K but NOT the S2000. These pistons can be used with the stock K block. If the K was a fiber block, you could not use these pistons without re-sleeving the block. That fact would be noted in the piston catalog.
On the other hand, no off the shelf pistons available for the s2000 because of the material that piston would have to be made of.
Old Nov 23, 2004 | 10:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (earl)
so how do you add after market pistons to the f20c?
Old Nov 24, 2004 | 12:49 AM
ZoRG's Avatar
Default Re: (Hella_JDM is back!)
you sleeve it.
Old Nov 24, 2004 | 12:59 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (ZoRG)
oh ok , whats the advantage to the stock sleeves ?
Old Nov 24, 2004 | 03:49 AM
Nikos's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Let me go out on a limb and say the K sleeves are not matrix metal. The reason I say this is that matrix metal blocks require a special piston also.
On the other hand, no off the shelf pistons available for the s2000 because of the material that piston would have to be made of.</TD></TR></TABLE>
Thank you Earl...
I guess the "new accord" the article was referring to was the euro R one with the h22a type S motor....
IRON IT IS
Old Nov 24, 2004 | 04:02 AM
ZoRG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM is back! &raquo;</TD></TR><TR><TD CLASS="quote">oh ok , whats the advantage to the stock sleeves ?</TD></TR></TABLE>
What the advantage of aftermarket sleeves to stock sleeves?
You can run pistons.
Old Nov 24, 2004 | 04:09 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (ZoRG)
i can run pistons in my d series with stock sleeves , im talking about why not with stcok f20c sleeves.
Old Nov 24, 2004 | 04:23 AM
ZoRG's Avatar
Cause the scratch the sleeves, I will see if I can find the link where someone posted pics.
Old Nov 24, 2004 | 05:48 AM
Oyvind Ryeng's Avatar
IMO, the aftermarket companies should experiment with making pistons/rings compitable with the fiber-sleeves, not the other way around. Guess they are more interrested in sleeving blocks than spending thousands of dollars on R&D.
Old Nov 24, 2004 | 07:48 AM
ZoRG's Avatar
Default Re: (Oyvind Ryeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">IMO, the aftermarket companies should experiment with making pistons/rings compitable with the fiber-sleeves, not the other way around. Guess they are more interrested in sleeving blocks than spending thousands of dollars on R&D.</TD></TR></TABLE>
Wouldn't you do the same?
Old Nov 24, 2004 | 08:10 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">IMO, the aftermarket companies should experiment with making pistons/rings compitable with the fiber-sleeves, not the other way around. Guess they are more interrested in sleeving blocks than spending thousands of dollars on R&D.</TD></TR></TABLE>I'm not even sure you can bore those fiber sleeves properly. Everyone just re sleeves the H series fiber sleeve Prelude block with ductile iron ones and runs aftermarket pistons. The same thing is now being done with the S2000.
mportracer33
Apr 2, 2007 05:12 PM
unusual71
Sep 24, 2005 02:39 PM
ensracer
Jan 17, 2005 04:09 AM
chulowithakhulo
Honda S2000
Jan 10, 2005 06:38 AM
ExospeedAMcrx
Feb 5, 2003 12:35 PM
