Wiring Questions?
cool guy name
I have a 97 CX, and a 97 JDM ITR waiting to go in.
My question is: In order to use the CX harness I would have run VTEC, do the IACV fix and also the CKF sensor plug. What the heck is the IACV fix and the CKF sensor plug??? I have searched and found numerous topics that tell me I have to do that but none that actually explain how to do it.
Also if I chose to use the JDM harness what all would I have to do other than extend the wires?
Thanks for the help. And again I tried searching, if someone would like to post some links to posts that explain this, it would be appreciated.
Thanks again,
Jim
Thanks again,
Jim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">the heck is the IACV fix</TD></TR></TABLE>
Your Civic has a 3 wire IACV, the ITR has a two wire.
http://www.ff-squad.com/tech/w...g.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">and the CKF sensor plug???</TD></TR></TABLE>
OBD2 + cars have a CKF sensor on the oil pump. It matters what ECU you will be running. If you run a OBD1 ECU, you do not have to worry about it. If you run a OBD2 ECU, you have to wire it up for to be CEL free.
https://honda-tech.com/zerothread?id=558245
http://www.ff-squad.com/technet/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Also if I chose to use the JDM harness what all would I have to do other than extend the wires?</TD></TR></TABLE>
It will not work. Integra harness = two pieces, Your civic = one. It is more time than you would want to spend on it.
cool guy name
Stupid question? Both the 97 Civic and the 97 JDM ITR are OBD2A or OBD2B? I'm thinking A. Thanks for the info, its very much appreciated.
Jim
Jim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Both the 97 Civic and the 97 JDM ITR are OBD2A</TD></TR></TABLE>
B18CivicEH2
Sep 10, 2007 07:10 PM
tha_badguy
Jan 10, 2006 10:34 AM
