that clicking noise is driving me crazy...!
Old Nov 23, 2004 | 07:41 AM
rice a roni's Avatar
Default that clicking noise is driving me crazy...!
ok so anyways i corrected the valve lash on my car several times but it still clicks...exhaust side to .010 of an inch and intake side to .008 of an inch and it still clicks...since the exhaust side can vary from .009-.011 and the intake from .007-.009 i thought it shouldnt make a difference rite? but it still clicks at 3000 rpms. could it be that the timing is advanced and making it click?? any help would be appreciated...
Old Nov 23, 2004 | 07:46 AM
Ricey McRicerton's Avatar
Default Re: that clicking noise is driving me crazy...! (allmighty2door)
Just so you know, a "slight drag" on the feeler guage is not a "slight drag". It's a very noticeable drag.
Old Nov 23, 2004 | 07:56 AM
Default Re: that clicking noise is driving me crazy...! (Ricey McRicerton)
i tightened it until i couldnt really pull it out.
Old Nov 23, 2004 | 07:58 AM
matz03's Avatar
does that noise go away after the car warms up, my car is making same noise but it goes away i wasn't sure what it was but i know i haven't reset the valve lash on my car yet.
Old Nov 23, 2004 | 08:12 AM
Default Re: that clicking noise is driving me crazy...! (matz03)
it goes away when it hits normal operating temperature but it is just ******* annoying to hear that clicking noise.
Old Nov 23, 2004 | 08:19 AM
BauleyCivic's Avatar
Risky Business
The valvetrain needs lubrication, unfortunately the oil pan is below the block and it takes a while for the oil to get up to the head and quiet down the valvetrain.
I used .009 and .011 for my valves, and they were wayyy to loud. Try .007 in and .009 ex that should quiet them a good bit.
Old Nov 23, 2004 | 08:22 AM
b18bcivic's Avatar
Default Re: that clicking noise is driving me crazy...! (BauleyCivic)
mine does the same thing till it gets warm-just deal with it
Old Nov 23, 2004 | 08:29 AM
mattssi's Avatar
what weight of oil are you using? 5w i imagine right? You want your valvetrain to be as quiet as possible. The louder it is, the more wear that is occuring.
Old Nov 23, 2004 | 08:42 AM
slambedcivic's Avatar
Default Re: (mattssi)
is it a VTEC engine?
if so, and your valves are correct, its most likely the lost motion sensors just below the cam(s)... there is nothing you can do to quiet them down unless you replace them. and when you do that, they ARENT cheap from honda.
Old Nov 30, 2004 | 11:14 AM
Default Re: (slambedcivic)
i got it working right...yeah...took me 30 minutes...anyways thanks for the input guys...
jaredvabeach
Apr 27, 2008 04:30 PM
sp00led
Sep 13, 2004 06:09 PM
Mikizzle
Nov 21, 2003 08:01 PM
Nizzy
May 17, 2003 03:14 PM
