Integra seats in a 97 Civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 »</TD></TR><TR><TD CLASS="quote">i believe 3 out of the 4 bolts will line up..otherwise you can just swap the entire bottom section of each seat</TD></TR></TABLE>
yupp
yupp
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">k thanks but is the cleareance under them the same also because under my seat i have an amp mounted?
TIA</TD></TR></TABLE>
That must me a tiny amp, I would say measure and find out. I have GSR seats in mine, but I don't have any amp underneath. Hit me up if you get your measurements, and I'll measure mine to see what clearance is like.
Chris
Chris
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
you don;t need to swap the entire bottom of the seat. all that is needed is one rail swap.
From: Why so you can pretend like youre interested, FL/OK
Don't list them, there is no need to go through the work of posting more on it when you're just going to get a similar answer as those already posted.
The seats will bolt up completely in the civic, you will just need to swap the rails over. It will probably take about 15 minutes if you haven't done it before. All you will need is a phillips head screw driver and a 10 or 12 mm socket or wrench.
Take off the plastic handle and screws on both sides that have plastic on them to expose the bolts. There are two bolts on the bottom of each rail, you will just need to slide the railing around to get to them at times. Don't forget the ones on the sides of the top of the rails. Once you look at it, you will understand which need to be removed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 »</TD></TR><TR><TD CLASS="quote">Ill have to go home and get the measurements tonight and list them for you guys</TD></TR></TABLE>
You do know I was speaking about the measurements for height so your amp would fit under the seat right?
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEHARDWAYEK »</TD></TR><TR><TD CLASS="quote">
-Chris </TD></TR></TABLE>
From the floor to the bottom on my civic seat there is excatly 6 inches. What is the distance from the floor to the integra GSR seats?
TIA
TIA
liquid:cooled
29
Mar 24, 2007 04:30 PM
WhoisDan
Jan 15, 2006 08:35 PM
illdstu
Apr 27, 2004 06:10 PM
