OEM seat swap between models (WHICH ONE WILL FIT?) -civic
eh2-eg6-prelude-integra......... im looking to put some OEM seats in my eh2 and was wondering which OEM seat will bolt in with no fabrication.
Re: OEM seat swap between models (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">94-01 Integra seats bolt into the EH2, no problem. Everything else you'll need to swap the inner rail or seat pans.</TD></TR></TABLE>
so pretty much eveything uses the same seat rail then, and what do you mean swapping the seat pan??... like the piece thats welded to the floorboard?
HT White Ops
Re: OEM seat swap between models (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Lude seats will not go in without cutting/welding or custom brackets. </TD></TR></TABLE>
Or swapping the seat pans (IIRC you can do this to the prelude seats).
Re: OEM seat swap between models (Eran)
okay well maybe we can sticky this someday...
so far we have seats that will fit a 92-95 eh2/ civic (and not sure about other model years)
- 94-01 integra/ GSR (no modification nessecary)
- prelude (years?) will not fit w/o swapping seat pans
how about 96-01 civic seats? do they use the same bolt pattern as the older gen?
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">No need for a sticky, this thread is pretty lack-luster. All this information (and more) can be found by searching.</TD></TR></TABLE>
i searched a lot but everything is so dilluted with for sale forums etc. and i couldnt find any solid information...
I'm a Jackass
Re: (liquid:cooled)
just buy the seats you want.. when you get them throw them in your car and see what you need to make them fit.. More than likely all your going to need to do is slot out the holes and maybe make a bracket or 2.. Pretty straight forward
Or swapping the seat pans (IIRC you can do this to the prelude seats).</TD></TR></TABLE>
I got a set out of my boss' car back in 2002 for swapping in his Sparco's and they didn't line up and I had no idea about swapping pans back then, so I have no idea.
Re: (Civic98KH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic98KH »</TD></TR><TR><TD CLASS="quote">would gsr seats work in an EK?...</TD></TR></TABLE>
All but one of the holes will line up.
Re: (ReDemoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDemoN »</TD></TR><TR><TD CLASS="quote">I put Delsol seats in my four door.
Had to do some bending and some cutting.
But they work and are in there.</TD></TR></TABLE>
I just switched out the rails to fit del sol seats into my 92 hatch
HT White Ops
Re: (hondajunkee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajunkee »</TD></TR><TR><TD CLASS="quote">with a hammer and a drill i mounted some 240sx seats in my crx lol</TD></TR></TABLE>
Sounds safe and classy.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Sounds safe and classy.</TD></TR></TABLE>
i know.. i want to stay away from ghetto'in seats in my car, im just still lookin for different seats i can simply bolt/ switch rails with..... i guess theres no more?
I bought my 93 Hatch with 00 SiR seats in it. The car has a ITR dash as well and these seats sit to high, I cant see the top of the gauge cluster (steering wheel blocks it). I would love to throw in some Del Sol or GSR/ITR seats but when trying to remove my driver seat the rear driver side bolt just keeps spinning, never actually backs out at all. Is it stripped? Should I cut the bolt, re-tap the hole and buy a new bolt?
