92-93 or 94-95 civic a/c lines??
Old Nov 23, 2004 | 05:41 AM
eg ferio's Avatar
Default 92-93 or 94-95 civic a/c lines??
ok im trying to put back togther my a/c in my 92 civic,but the thing is i purchased all th lines with dryer from a junkyad and didnt notice if they were from a 92-93 or a 94-95 and i know there is a difference....my question is how would i distinguish them from 92-93 to 94-95?....your help is appreciated
Old Nov 24, 2004 | 03:19 AM
eg ferio's Avatar
Default Re: 92-93 or 94-95 civic a/c lines?? (eg ferio)
up
Old Nov 24, 2004 | 09:06 PM
eg ferio's Avatar
Old Nov 24, 2004 | 09:57 PM
=GAME='s Avatar
the lines should be the same. as for the drier, ditch the junkyard one and get a OEM one for about 30 bucks. only difference in 92-93 and 94-95 is the r12 and r134.
Old Nov 24, 2004 | 11:06 PM
cursED's Avatar
Default Re: 92-93 or 94-95 civic a/c lines?? (=GAME=)
Part numbers for the 92-93 dryer are different from the 94-95. May want to check with the dealer to see if there is a difference, and test fit the lines on whatever dryer you end up with (if they happen not to be the same).
Sorry, I can't tell you for sure if there is a difference in those lines, but a buddy of mine replaced his condenser, and the fittings are different between the R-12 & R-134a parts.
Old Nov 24, 2004 | 11:07 PM
civicsisi's Avatar
actually they are diff. 92-93 is one style and the 94-95 is another. the 2 are not compatible
in 93 some cars came with r12 and some r134 but they kept the same lines during that year.
the 94-95 line conecting ends are larger/fatter and appear to stubbier so to speak (sorry i dont have a picture), they will not seat into the 92-93 line components.
i found all of this the hard way. hope this helps you out.
Old Nov 25, 2004 | 03:13 AM
Deemeetree's Avatar
Electrician
Default Re: 92-93 or 94-95 civic a/c lines?? (civicsisi)
This should narrow everything down a bit.
1992-1993:
Condensor:
80110-SR1-A12
Compressor:
38810-P06-A03
Pipe A:
80341-SR1-A11
Pipe:
80331-SR1-A11
Pipe B:
80342-SR1-A11
Pipe:
80321-SR1-A11
Discharge:
80315-SR1-A11
Suction:
80311-SR1-A11
Pipe:
80322-SR1-A11
Pipe:
80343-SR1-A11
1994-1995:
Condensor:
04801-SR1-305
Compressor:
38810-P76-016
Pipe A:
80341-SR1-A12
Pipe:
80331-SR1-A12
Pipe:
80321-SR1-A12
Pipe:
80315-SR1-A12
80315-SR1-A32
Pipe:
80311-SR1-A32
80311-SR1-A12
Pipe:
80342-SR1-A22
Pipe:
80343-SR1-A22
Pipe:
80322-SR1-A22
As you can see, everything is different on the 1992-1993 system vs. the 1994-1995 system. I am not entirely sure if you can modify the lines to fit, but then again, it brings up the R12 vs. R134 issue.
Old Nov 25, 2004 | 05:12 AM
eg ferio's Avatar
Default Re: 92-93 or 94-95 civic a/c lines?? (Dimi)
dimi thank you so much man i really appreciate it and the same for everyone else
Old Nov 25, 2004 | 05:19 AM
Deemeetree's Avatar
Electrician
No problem.
battlecrxT
Welding / Fabrication
Oct 11, 2006 05:47 PM
CLE
Jul 17, 2006 12:25 PM
4DooRGiSzer
May 25, 2004 03:51 PM
