Axle issue's
Old Nov 23, 2004 | 03:39 AM
abeaujuin's Avatar
Default Axle issue's
I am getting this rumbling sound and feel everytime I step on the brakes hard while coming to a stop. It feels like the axle is shaking underneath the car.
I just replace the axle Twice. The first time the axle was causing my steering wheel to vibrate as I excelerated so I changed it. Now it does it while I am braking.
Could it be the axle again? I look underneath the car and everything looks fine.
Old Nov 23, 2004 | 05:19 AM
maroonaccord2.2's Avatar
Default Re: Axle issue's (abeaujuin)
Could be your brakes, or maybe a wheel bearing. It's most likely not a half shaft problem.
Old Nov 23, 2004 | 05:29 AM
abeaujuin's Avatar
Default Re: Axle issue's (maroonaccord2.2)
I just don't understand why after I changed the Axle this happened?
I do feel something going on with the brakes. When I am at a light, the car starts to roll while I am stepping on the brakes which just worked fine. I feels like the pedal is sinking to the floor little by little and I have to pump them to get it to work.
Old Nov 23, 2004 | 06:02 AM
srfnscubamunkey's Avatar
If your car feels like it is pulsating while it is "rumbling" then you might have a warped rotor(s)
Old Nov 23, 2004 | 09:32 AM
abeaujuin's Avatar
Default Re: Axle issue's (srfnscubamunkey)
A warped rotor in just a few hours? I don't understand. The last thing I did was replace the Axle and now I test drive the car and it rumbles like the axle is loose which it isn't I went over everything and everything looks good.
Old Nov 23, 2004 | 01:57 PM
91EXRMANUAL
Guest
Posts: n/a
Hey my breaks let go all the time to , i had to put it in nutral at lights becuase they let go on me and i had to keep pumping them once and a whyle
need master cylinder
cmasino
Honda Civic (2001 - 2005)
Jul 14, 2017 10:44 AM
Ilovemyef9
Feb 20, 2007 08:12 PM
DaMmniTz
Feb 6, 2005 04:07 AM
Dank26
Oct 29, 2001 10:23 PM
