Asking Grade Logic Control in Automatic Trans
Dear all
Sorry.
I just want to asking regarding Grade Logic Control (in AT ) in Honda (CRV, Stream, etc )
How that things work ? using a sensor or work by others mechanical ?
Thank You
Sorry.
Thank You
I don't think anyone has any idea what you're talking about.
If you mean what controls shifting in an automatic transmission then it's a combination of electronic and mechanical controls.
I mean regarding the shifting in AT. Cause if Honda Transmission use Grade Logic Contorl, it will keeps our transmission in position 2nd to get more power in climbing hill road. maybe in other transmission will change to 3rd gear. I just wondering how it works? how this AT with Grade Logic Control know that the car is on climbing situation, so it can keep the gear. Base on what ?
thx
thx
pls look
http://automobiles.honda.com/m...=True
thx
thx
pls look
thx
thx
The service manual doesn't make much mention of it. It appears that the ecu just compares how much throttle is being applied versus how much the car is accelerating, and bases gear choice on that. I think it uses the coolant temperature sensor and the ATF temperature sensor to detect more load on the engine and trans as well, helping to determine the appropriate gear.
Sorry I don't know any more, but I'd like to see what other people make of this.
Gradient is the angle of a hill, so it uses the extra load to figure out how steep of a hill it's climbing.
I wonder if the barometric pressure sensor is sensitive enough to detect a tiny change in elevation like a moderate hill would give. It says it uses the sensor in determining the gradient, so I guess so.
Sorry,
what is barometric pressure ? soory i really don't understand it.
and where the position of these sensor ?
is it under the machine so it can read the road level, likte tiny camera ??
sorry,
thx
sorry,
thx
Barometric pressure is the air pressure. It changes with the altitude, obviously, and the ecu needs to correct for the less dense air at higher altidudes above sea level. The sensor is inside the ecu, and by monitoring the readings of this sensor, the ecu can determine whether the car is going up a hill or down, depending on whether the air pressure is falling or rising. The closer to sea level you get, the more dense the air gets.
Well like the diagram shows, the ecu controls the shift solenoids that determine the gear the transmission is in, so it just does whatever it wants.
