Car surges at WOT with rpm meter flickering after 3k =*(
Old Nov 22, 2004 | 08:38 PM
diM.'s Avatar
Default Car surges at WOT with rpm meter flickering after 3k =*(
Car runs fine while driving it regularly, but when i punch it.. the needle goes stupid after 3k. ex. 3..4..7..8.9k
The motor is like " surging " with the rpm flickering at WOT.
When I rev up to 8k while idling, it goes up and down normally.
car - 97' gsr with skunk2 manifold, kenji obd1 with harness and i/h/e.
approx. 75k miles.
This happen like just a month ago.
Posting in ITR forum because they are teh smart
Old Nov 22, 2004 | 09:01 PM
Art Vandeleigh's Avatar
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (d-_-b)
could it be a slipping clutch? had that happen with my 1993 accord. once I put in a new PP and disk no more surging and runs like a champ.
Old Nov 22, 2004 | 09:05 PM
waijsR's Avatar
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (Art Vandeleigh)
hmm whith my GSR, I only had that problem after I jumped the car... did you jump the car then drive it when this was happening?
Old Nov 22, 2004 | 09:08 PM
92TypeR's Avatar
FSAE
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (slyfoxITR)
Check MAP sensor. Same thing happened with my '95 GSR...turned out to be a screwed up MAP plug. Although the tweaked out RPM's doesnt sound familiar. Check the main engine ground and tranny ground too.
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d-_-b &raquo;</TD></TR><TR><TD CLASS="quote">The motor is like " surging " with the rpm flickering at WOT. </TD></TR></TABLE>
does the motor rev surge to a higher rpm as if it is in neutral? if so, i believe you have a slippin' clutch.
Old Nov 22, 2004 | 09:10 PM
BlueR's Avatar
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (nightrider)
ditto on the slipping clutch...
you have all the symptoms
Old Nov 22, 2004 | 09:16 PM
niterida's Avatar
My old civic did exactly the same thing when I did the b16 swap. It was the distributor wires. When I would punch it the tach would jump wildly thorugh the rpm range. It turned out to be a loose connection. You might want to check all of the wires around the distributor.
I think this is what you are describing, if it was you clutch you would smell tons of burning and see smoke if it was that bad. plus the car wouldn't go anywhere
Old Nov 22, 2004 | 09:21 PM
diM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">
does the motor rev surge to a higher rpm as if it is in neutral? if so, i believe you have a slippin' clutch. </TD></TR></TABLE>
car idles fine.. my clutch does have a squeaking noise when i step on and off it, but the honda mechanic told me that it was just bad lube?
im thinkin its a electrical prob, but no check engine lights or throwing codes
Old Nov 22, 2004 | 09:24 PM
diM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slyfoxITR &raquo;</TD></TR><TR><TD CLASS="quote">hmm whith my GSR, I only had that problem after I jumped the car... did you jump the car then drive it when this was happening?</TD></TR></TABLE>
na uh
Old Nov 22, 2004 | 09:26 PM
BlueR's Avatar
so this only happens when the car is under load @ wot?
Old Nov 22, 2004 | 09:27 PM
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (niterida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niterida &raquo;</TD></TR><TR><TD CLASS="quote">
I think this is what you are describing, if it was you clutch you would smell tons of burning and see smoke if it was that bad. plus the car wouldn't go anywhere </TD></TR></TABLE>
that is 100% WRONG. if you were to see smoke comming out because of a slipping clutch then you have other serious problems!! you might smell something but still highly unlikely. again as i said it could be your clutch slipping as I had the same symptoms with my 93 accord....OR it could also be what niterida said about the distributor. you could have some loose wires...this is well documented for the second generation integras and could possibly be what you have.
Old Nov 22, 2004 | 09:32 PM
diM.'s Avatar
Default Re: Car surges at WOT with rpm meter flickering after 3k =*( (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">so this only happens when the car is under load @ wot?</TD></TR></TABLE>
yes sir
Old Nov 22, 2004 | 09:33 PM
BlueR's Avatar
short of driving the car myself, my best diagnosis is a slipping clutch
mynameizstitch
Feb 21, 2012 12:41 PM
trooper0641
24
Jan 13, 2006 02:34 PM
Thanks knightsport!
Jul 1, 2005 08:50 PM
ace42004
May 18, 2005 03:18 PM
Jstue
Dec 25, 2003 09:41 AM
