89 acura legend check engine light info
i was wondering if anyone knows how to check the codes for an acura legend.
i looked under the floormat in the passenger side and i counted the red light 7 times, but when i start the car there is an orange light next to it, what is that?
also i found on a website the engine codes or so i believe, is code 7 the throttle angle sensor?
what the hell is that on a legend, how much is it used?
thanks.
thanks.
fwiw:
http://www.stanford.edu/~voloshin/ltech.html#codes
http://www.legendarylegendz.co...s.doc
hope that helps
hope that helps
yes it doeshowever, i read in the webpage that you posted "All you have to observe is a little red LED (there may also be a yellow LED flashing, but that is another unrelated story)."
what is the yellow led?
also do you have any information on an 88 legend throttle angle sensor?
okay this explains the yellow led in case any one else needed also :
http://www.autozone.com/servle...c.jsp
it has to do with the idle speed adjustment.
site also has info for the throttle angle
nikkums1021
Acura TL, RL & ZDX
13
Mar 30, 2012 07:22 AM
G. Man
12
Feb 25, 2011 06:13 PM
