Passenger side window problem
Old Nov 22, 2004 | 07:08 PM
Devilry's Avatar
Default Passenger side window problem
ok I know it fell off the track, and the Haynes manual says to un-do the bolts with the window all the day down.. so I can put the window back on. But my problem is that the window is all the way up and wont go down but like a 1/4 inch. So.. what do i do?
Anyone have any knowledge on this? Thanks!
Old Nov 22, 2004 | 07:16 PM
Cuong-nutz's Avatar
Default Re: Passenger side window problem (Devilry)
there are two 10mm bolts that hold THAT AT LIKE A LEVERAGE for the window track. It's not the 4 bolts that hold the regulator. be careful when undoing those nuts. once that track comes out the windows gonna fall, depending on the cases.
Old Nov 22, 2004 | 07:25 PM
Devilry's Avatar
Default Re: Passenger side window problem (Cuong-nutz)
Yeah I started to unscrew one of those bolts and stopped thinking maybe I shouldn't... im gonna go ask Honda-Tech just to verify.. heh.. so your basically saying to make sure i secure the window not to fall first right?
Old Nov 22, 2004 | 07:35 PM
Cuong-nutz's Avatar
If the window is off the tracks---like between the seal and the metal rail, then it's probably not gonna fall down on yah. Just unbolt with one hand and hold the glass with the other.
phong3992
20
Mar 4, 2011 01:29 AM
TwoKSiR
Nov 4, 2007 02:33 PM
tx95excoupe
11
Sep 14, 2007 05:43 AM
WhiteOnRice
Mar 8, 2007 03:32 PM
