wheel tire height
1990 crx si with 205/40/zr17 cant find the formula to calculate if these are taller than stock i know its a bigger wheel but a big difference in the series of the tire could me speedo be off now and if someone know is there enough difference for it to be off alot thanks
sorry wrong area dont know how to move it now
alright i cant post anymore i checked tire rack stock wheel tire 914 rpm
mine 886 stock dia. 22.8 in mine 23.5 is this enough to throw the speedo off alot
Modified by elrandeeto at 8:27 PM 11/22/2004
If you look on the specs charts on tire rack, each tire will have a revs per mile number associated with it. Check it for a 185/60/14 tire vs 205/40/17 tire, and that should give you an idea.
205 =tread width
40%of tread width =sidewall height
17 wheel diameter.
does that help? your total sidewall height x 2 + wheel diameter= total height
3.225 in x 2 + 17in =23.456in
17 wheel diameter.
typer0853
Mar 2, 2006 06:41 PM
djnikko
Mar 24, 2005 03:13 PM
