fuel rail
Old Nov 22, 2004 | 06:22 PM
13secondmonster's Avatar
Default fuel rail
i just put in my str fuel rail on my h22 and lost a full tank of gas in five minutes but nothing is leaking off the rail or any hoses. help?!?!?!?
Old Nov 22, 2004 | 06:25 PM
iam7head's Avatar
Default Re: fuel rail (13secondmonster)
what is your set up?
what size of injector?
what is the F/P ratio and pressure?
what is the idle?
5minute for 15+/- gallons?
i wouldnt suggest you to smoke near your car, because i think you have a big **** leak.
Old Nov 22, 2004 | 06:37 PM
h22 str fuel rail holley fpr running 47 psi with stock injectors but my fuel gauge is erratic. before i put the new rail on i ran at 47 then i put on the str and the gauge became erratic jumping from 60 to 80 but the car responds great. all of a sudden i smell gas and its everywhere. i think it mite be coming from the fuel line at the banjo bolt because all injectors are try and the regulator is tight with all lines secured. and i dont smoke around the car!!!????
Old Nov 22, 2004 | 06:58 PM
iam7head's Avatar
check the area around the FPR and the FPR guage, i think that would be the weakest connection.
mang, becareful i think you have a big leak somewhere.
one way to spot leaks to by using black light, get some of those bastard(a replace for your regular blub)at Urbanoutfitter, turn it on at night and it will read you some leak.
street_ride14
Jul 26, 2009 02:10 PM
jaydm ferio
12
Jan 20, 2005 11:47 PM
pureplayaz704
Mar 29, 2003 11:55 PM
JoshRambo
Sep 16, 2002 03:54 AM
schwett
Aug 30, 2001 03:28 PM
