Which accord trannies are interchangeable (Automatic)
Old Nov 22, 2004 | 06:13 PM
loudsubz's Avatar
Default Which accord trannies are interchangeable (Automatic)
I did a search but didn't find much. What years work and are swapable?
My uncles 2000 accord auto went and hes looking for a new one.
They have the I4 model, so im wondering from what year F series trannies are interchangeable, and if the v6 and I4 also swap
thanks.
Modified by loudsubz at 7:52 PM 11/24/2004
Old Nov 22, 2004 | 07:11 PM
pyrojeff's Avatar
Default Re: Which accord trannies are interchangeable (loudsubz)
I really doubt any of the F-series trannies will work on a V6. Probably have to look into a late model Acura CL/TL tranny. All F22 and H22/23 trannies are interchangeable with each other, but not on the V6.
Old Nov 22, 2004 | 07:31 PM
v4lu3s's Avatar
RTFM
you need a v6 tranny from a 6th gen accord or you can try some ofhte late model acuras but you may need ot mod a bit then.
Old Nov 22, 2004 | 08:03 PM
Legendaryyaj's Avatar
Default Re: (v4lu3s)
What was the reason for it going out? Honda has a extended warranty for the 00-02 v6 guys if you are under 100k. The only trannies that will work will be from the TL/CL but might require some modification. You can also put in a CLS 6 spd, but of course mod will be needed(mostly wiring issues).
If you plan on replacing it with another regualr one, opt for the 98-99 trannies, they seem to be stronger than the 00-02.
Old Nov 23, 2004 | 07:38 AM
loudsubz's Avatar
Default Re: (Legendaryyaj)
ok thanks for all the replies
i found it its not a V6 its just the I4 auto
since the trannies are swapable, is there a year limit? I mean, on honda civics i know you can swap all 92-00 D series trannies etc, but i know an auto tranny from a 4th gen civic wotn swap into a 5th or 6th, does it work the same with the accord or does any year work.
I found a guy selling a 94 auto tranny thats why i was wondering
thanks.
Old Nov 23, 2004 | 10:34 AM
pyrojeff's Avatar
Default Re: (loudsubz)
As far as I know, all F22A, F22B, F23, H22, and H23 transmissions are interchangeable, so the F22B transmission should work.
Old Nov 24, 2004 | 06:54 PM
loudsubz's Avatar
Default Re: (pyrojeff)
someone mentioned to me the 2.2 and 2.3l trannies were diff and didn't work, is this true?
he mentioned only 98+ would work on a 2000 and that 94-97 2.2l model, the tranny would not swap
any truth to this
Old Nov 25, 2004 | 12:58 PM
eauto's Avatar
Yes. Based on my research, only 2.3L trannies will fit.
Old Nov 25, 2004 | 04:21 PM
TOAB's Avatar
any tranny from an F or H series motor should work i think
Bash350
May 2, 2018 09:17 AM
NemoDat
Acura TSX
Dec 11, 2012 05:08 PM
dcmystery21
Apr 23, 2009 07:39 PM
Reklaw_Cl
Jun 15, 2007 12:51 PM
