Help with wheel problem.
Hi I have a 91 integra. I noticed lately that my driver side wheel has a little bit more play than normal. I checked the pass side and it was fine. I would kick the driver side wheel and it would jerk and I can move it back and forth just by kickin it. The pass side doesn't do it. It's stiff but the driver side it moves back and forth everytime I kick it. I wanna know what's wrong with it and how do I fix it. Somebody told me that my bushings or something like that might be bad and it's causing the wheel to move back and forth. Any help would do TIA.
If you get the same amount of slop when you grab the tire at the top and bottom as when you grab it at the left and right, it's likely the wheel bearings. If it's at left and right (especially if the steering wheel is locked) but not top and bottom, it's likely the tie rod end(s).
Ok I tested it. I can move the wheel studs from right to left without spinnin the hub. It's the wheel bearing huh? Where can I go to get it replaced? I would do it myself looks simple enough I just don't have the time because I'm a workaholic and I don't have a puller or a presser?
09egkid
Aug 6, 2010 02:54 PM
Mr. Vapor
Dec 5, 2002 05:29 PM
