code 43, make it go away.
Old Nov 22, 2004 | 12:44 PM
GSRCRXsi's Avatar
Default code 43, make it go away.
ok if i drive my car at the same rpms for an extended period of time, like just cruising, my cel pops up with a code 43. absolutely nothing is effected, no rpm limit, vtec still works and no apparent loss of power. now helms tells me that code 43 is the fuel system/o2 sensor. whats going on? has anyone had this happen?
Old Nov 22, 2004 | 01:08 PM
HatchBox's Avatar
Skoobie no more...
Default Re: code 43, make it go away. (GSRCRXsi)
the ecu blinks 43 times???
it would help to know what engine/ecu your running also
Old Nov 22, 2004 | 01:11 PM
EL Vap133's Avatar
I'm assuming you have a CRX with a B18c1?
Old Nov 22, 2004 | 01:12 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">ok if i drive my car at the same rpms for an extended period of time, like just cruising, my cel pops up with a code 43. absolutely nothing is effected, no rpm limit, vtec still works and no apparent loss of power. now helms tells me that code 43 is the fuel system/o2 sensor. whats going on? has anyone had this happen? </TD></TR></TABLE>
It's not O2 sensor.
It's fuel supply.
No idea, but the helms should have a full out test procedure for you to follow.
Old Nov 22, 2004 | 01:16 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote"> my cel pops up with a code 43. has anyone had this happen? </TD></TR></TABLE>
You mean like 4 long blinks and 3 short blinks? My OBD0 LS swap with the PR4 does this sometimes. I just reset the ecu and go on. Doesn't seem to cause any problems. I would also like to know what is going on.
Old Nov 22, 2004 | 01:17 PM
hatchinprogress's Avatar
Default Re: code 43, make it go away. (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">the ecu blinks 43 times???
</TD></TR></TABLE> are you serious? code 43: 4 long "flashes" and 3 "short" flashes by the way i had that code on my dohc zc and i think it had somethin to do with the egr valve? (been a while but i think thats what it was)
Modified by hatchinprogress at 2:43 PM 11/23/2004
Old Nov 22, 2004 | 02:34 PM
BlueShadow's Avatar
Did you just recently install the motor in there?
Mine did that too, but it was right when I first cranked the motor up. My fuel system wasn't primed up all the way, so it took me three attempts to start the car. ALl I had to do was disconnect the neg battery terminal to reset the ECU and I got rid of the code 43.
Old Nov 22, 2004 | 03:27 PM
GSRCRXsi's Avatar
Default Re: code 43, make it go away. (BlueShadow)
well this is the second time ive had this happen. the motor is a b18c1, obd1, sorry should have mentioned that. i dont have an egr valve. and the motor has been installed for over 2 years. never saw the code til i got the car back from being stolen. it didnt happen for a while and now its popped up again. ill reset the ecu and see if it happens again.
what in the fuel system can cause this? nothing is affected, and the fuel filter is brand new. and if the helms says that code 43 can be caused by the o2 heater circuit then why cant it be the 02?
Old Nov 22, 2004 | 08:20 PM
mannyman's Avatar
El Veterano de Sur Califas
welcome to the club. I get this code often aswell, mines seems to pop up when i sit at idle for a long time. But has been known to pop up when just driving rugular. And I have noticed that it affects my gas mileage when the cel is on. And The culprit in my case is my fpr. Its a b&m and when I adjust the screw almost all the way out(with the motor off) and start my car, the cel instantly comes on. so, im sure it has to do with my fpr. You might want to get a nother fpr and check to see if your cel comes on again.
manny
Old Nov 23, 2004 | 08:39 AM
GSRCRXsi's Avatar
Default Re: code 43, make it go away. (mannyman)
someone said that the screw on the end of the fuel rail can effect it too. is that screw supposeed to be tight? i think last time i took that cap off it was real loose.
Old Nov 23, 2004 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">someone said that the screw on the end of the fuel rail can effect it too. is that screw supposeed to be tight? i think last time i took that cap off it was real loose.</TD></TR></TABLE> it needs to be tight
Old Nov 23, 2004 | 10:25 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: code 43, make it go away. (hatchinprogress)
that screw has been absolutely out on both A6 motors i've had... i put it back in and the vibration takes it back out... but the A6 doesnt throw a code.
Old Nov 23, 2004 | 10:58 AM
GSRCRXsi's Avatar
what does that screw do?
Old Nov 23, 2004 | 11:01 AM
manson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> are you serious? code 43: 4 long "flashes" and 3 "long" flashes by the way i had that code on my dohc zc and i think it had somethin to do with the egr valve? (been a while but i think thats what it was) </TD></TR></TABLE>
long flashes = 10
short flashes = 1
if you had 4 long and then a pause and then 3 long that is something totally differnt.
EDIT*
anyways im not sure on how to fix your problem .... hope into the manual.
good luck.
Modified by manson at 3:40 PM 11/23/2004
Old Nov 23, 2004 | 11:15 AM
GSRCRXsi's Avatar
Default Re: code 43, make it go away. (manson)
a pause denotes a break, or a new code. so if it flashed 4 long times, paused, then 3 long times, that would be code 40 and code 30.
mine flashed 4 long times then 3 short times, then paused and did it again.
4*10+3=43
Old Nov 23, 2004 | 11:40 AM
manson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">a pause denotes a break, or a new code. so if it flashed 4 long times, paused, then 3 long times, that would be code 40 and code 30.
4*10+3=43</TD></TR></TABLE>
Whoops..... i jumped ahead of what i was writting.... lol...
thats what a meant.
Old Nov 24, 2004 | 10:35 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">what does that screw do?</TD></TR></TABLE>
it's a fuel pulsation dampener
Old Nov 25, 2004 | 11:25 AM
mannyman's Avatar
put some thread lock on it, so it wont vibrate loose. and i fixed my 43 CEL. i uped the FPR some more, and it havnt gotten the CEL to come on.
manny
tonyguns
Apr 21, 2008 03:33 PM
JDMhondalude22
Nov 8, 2006 04:55 AM
Elbowpunk
Feb 3, 2006 06:50 PM
DarkBB4
Aug 27, 2005 09:31 AM
HXMan
Jun 16, 2001 07:46 PM
