crippled gsr crx
maybe u have one bad *** cam and when u hit 3k it wakes up! doubt it but its ignition check that dizzy!..check coil might have excessive resistance. pull the cap off and see if its chewed up in the coul hole and stuff..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrx »</TD></TR><TR><TD CLASS="quote">still having stumbling problems during lo rpms........never had this prob b4. runs like caca until i get around 3k rpm. any ideas ne 1?</TD></TR></TABLE>
Sounds like the same problem I have been fighting for the last 6+ months. Does this happen at full throttle or part throttle.
Here is a links to some of my posts about my problems.
https://honda-tech.com/zerothread?id=1073250
Let me know if you need anything and I will help as much as I can.
Sounds like you may have a faulty O2 sensor. Try unplugging it and seeing how it runs. I had terrible problems with my civic related to partial throttle and low rpm stumbling. With a new sensor, the problem went away.
-Alex
-Alex
WAFFLES
Apr 25, 2003 01:42 PM
