Cam Question
Old Nov 22, 2004 | 08:48 AM
hondaluva's Avatar
Default Cam Question
I've been offered the cams below for my b18b for $300 and wondering how they will perform. I know i'll need 11.0:1 compression or higher and a fully built head with valve springs, retainers, port and polish, high flow intake manifold, and oversized throttle body. Just had a few questions before i make my decision. thanx for the help....
Crane Cams for non vtec b18b part number 101-0016
Duration: 246/246
Duration @ .050 In/ex: 218/218
Gross Lift: 433/433
Questions:
1) How is the idle on these?
2) Would these be to radical for daily driver usage?
3) How do they compare to Crower 403 and 404 in the same motor?
4) Anybody got any numbers they put up using these?
oh yeah the motors is in a 96 Integra
Old Nov 29, 2004 | 08:04 PM
hondaluva's Avatar
Default Re: Cam Question (hondaluva)
Come on ya'll no response in a week can i get a lil help please
Old Nov 29, 2004 | 09:24 PM
HobbesGSR's Avatar
That's a pretty big cam... pretty much meant for the strip. Idle will by lopey, but not terrible ... pretty radical for a daily driver ... similar specs to a crower 404- but these are only #s ---- my advice: 1) figure out what exactly you want 2) do some research
Old Nov 29, 2004 | 09:27 PM
hybrid_vtec's Avatar
lookz to be closer to the Crower 403 grind than the 404! $300 is a good deal IMO!
Old Dec 2, 2004 | 05:40 PM
hondaluva's Avatar
they sem to be in the middle of the crower 403's and 404's. Which should be ok for daily driver. I dunno??????????? Where are all the all motor ls builder out there, I need some heelp?
Old Dec 3, 2004 | 06:41 AM
hondaluva's Avatar
Bump for some more input
Old Dec 3, 2004 | 07:27 AM
qcktegls's Avatar
the 404's are not very streetable but can be used. the idle can be rough at times. im sure with the cams u want, if you tune them right u should alright. but make sure you have all the other things in place for those cams like you said. other than that looks like a good buy
Old Dec 3, 2004 | 08:08 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Cam Question (qcktegls)
Sounds like a good street cam, its not too wild.
Old Dec 5, 2004 | 06:40 PM
hondaluva's Avatar
thanx for the input peeps anymore input
Old Dec 6, 2004 | 06:04 AM
hondaluva's Avatar
anymore opinions out there or somebody actually using these cams
Old Dec 8, 2004 | 06:02 AM
hondaluva's Avatar
bump
Alfred Liu
Dec 6, 2015 09:34 PM
bradysyde
Aug 27, 2012 10:05 PM
pauld
Jun 22, 2007 12:56 PM
OoCRXoO
May 4, 2003 12:22 PM
