Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
going from welded to LSD, will I be disapointed?
Old Nov 22, 2004 | 07:59 AM
Chris Sawatsky's Avatar
New User
Default going from welded to LSD, will I be disapointed?
I raced this season on a welded diff in my ITA crx, but I'm considering putting in a gear based (OBX) limited slip for next year as I plan to take a season off of road racing to autoX. Will I be disapointed when I get back to the track, having less lock up between the front wheels?
I really liked the braking/turning/accelerating of the locked from end, but of course slow maneuvers in the pit, etc, are a pain.
My concern is that the lsd won't lock as much. Has anyone gone from welded to lsd and is able to comment on the change?
thx
Old Nov 22, 2004 | 08:20 AM
KIWI's Avatar
Default Re: going from welded to LSD, will I be disapointed? (Chris Sawatsky)
I'ts been a long time, but I used to run a Mugen Crx back home in New Zealand. We welded up the diff as there was no aftermarket LSD's available at the time. I gained over two seconds a lap by using the locked diff... And yes I agree it was a pain to drive around the pits but the thing cornered and pulled out of corners like a dream! I don't think you will be disapointed going to a regular LSD. But I think you will notice a big difference in ease of driving. However if you are used to the Locked diff the transition to an LSD should be easy.
Good Luck.
Kiwi
Old Nov 22, 2004 | 09:00 AM
rice_classic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Sawatsky &raquo;</TD></TR><TR><TD CLASS="quote">I raced this season on a welded diff in my ITA crx, but I'm considering putting in a gear based (OBX) limited slip for next year as I plan to take a season off of road racing to autoX. Will I be disapointed when I get back to the track, having less lock up between the front wheels?
thx</TD></TR></TABLE>
You have a right to be concerned. A welded diff is 100% lockup (duh) and the OBX diff. (which is identical..i think..to the quaife) is around 35% lockup. You might find that your understeer/oversteer will be affected.
vti444
Transmission & Drivetrain
May 17, 2009 12:13 AM
racer76j
Mar 8, 2009 04:59 AM
boosted_dc2
Mar 6, 2004 04:29 PM
Garrett
Jul 21, 2003 06:33 PM
Timmayeg
Aug 28, 2002 04:32 PM
