Is there any installation required to hookup a Hondata s200 system?
Is there any installation required to hookup a Hondata s200 system? Do wires need to be soldered or anything like that?
Thanks
Thanks
if ur doing it urself and then getting it tuned at a dyno just have the dyno shop install it for ya. most shops will do it for free cause it takes only a couple of min. saves you time
Installation instructions can be found at http://www.hondata.com/downloads.html
Once the ECU has been socketed, you only need to connect (1) wire, install a low-profile ZIF socket (optional, but highly recommended), and either a 28-pin chip or ROMulator.
