Atmel 29c256 Discontinued...
Old Nov 22, 2004 | 05:58 AM
Enthalpy's Avatar
Default Atmel 29c256 Discontinued...
Hey ECU tuners.
Atmel has discontinued production of all 28pin and 30pin platforms as of mid October...
SO...what are your ECU hackers reccomending for an EEPROM?
Old Nov 22, 2004 | 06:00 AM
racinskittle's Avatar
Default Re: Atmel 29c256 Discontinued... (Enthalpy)
****. AMD doesn't have a replacement chip out either
Welp, i guess we'll all be running on ROMulators
Old Nov 22, 2004 | 07:10 AM
Rain_man's Avatar
New User
Default Re: Atmel 29c256 Discontinued... (racinskittle)
Looks like a good idea to buy up remaining stock!
Old Nov 22, 2004 | 07:21 AM
raene's Avatar
27SF256 maybe?
I don't know anyone that's tried one yet though.
Old Nov 22, 2004 | 07:22 AM
Tchleung's Avatar
what's teh diff between those and the oens I've bene using? I've been jsut using ATS29c256 or something liek that
Old Nov 22, 2004 | 07:31 AM
TrueNorthStar's Avatar
Default Re: (Tchleung)
the 27c's are write once I think or UV erasable. Either way you can use the 29c256 for tuning other peoples cars and then burn thier .bin's to a 27c256.
At least that is what I'm going to do for now.
Old Nov 22, 2004 | 10:03 AM
raene's Avatar
Default Re: (TrueNorthStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">the 27c's are write once I think or UV erasable. Either way you can use the 29c256 for tuning other peoples cars and then burn thier .bin's to a 27c256.
At least that is what I'm going to do for now.</TD></TR></TABLE>
Do a search on the 27SF256... it's not OTP, it's flash-eraseable.
Tchleung, theoretically there shouldn't be a difference (as far as I can see). But like I said I don't know anyone that's used them successfully yet.
Old Nov 22, 2004 | 10:32 AM
Del_Slowest's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Tchleung, theoretically there shouldn't be a difference (as far as I can see). But like I said I don't know anyone that's used them successfully yet.</TD></TR></TABLE>
i think blundar uses those. you might want to pm him and ask
Old Nov 22, 2004 | 10:56 AM
seen4ever's Avatar
https://honda-tech.com/zerothread?id=1060949
digikey still has a good deal of the 29c256-70's in stock. i know someone was emailing in the thread i made last week.
Old Nov 22, 2004 | 12:31 PM
Cyphear's Avatar
My willems burner doesnt like the 27SF256's. i tried a lot of stuff but couldn't get it to burn.
Old Nov 22, 2004 | 12:37 PM
SOHC_MShue's Avatar
Default Re: Atmel 29c256 Discontinued... (seen4ever)
**** what am i going to do...i got the moates burn1 burner . I guess i'll go order some now...
Old Nov 22, 2004 | 01:16 PM
hoggy's Avatar
Default Re: (Cyphear)
I couldn't get my willem to burn 27sf256's. I've tried on my batronix with no luck as well even though they both are supposed to support the chip. I wish I knew what i was doing wrong.
Old Nov 22, 2004 | 01:26 PM
JDMs1eeper's Avatar
Default Re: Atmel 29c256 Discontinued... (SOHC_MShue)
damn that sucks.... hopefully i can get a couple chips. If not, hondata here i come i guess
Old Nov 22, 2004 | 01:38 PM
Jefnes's Avatar
Buy an adapter and goto a 32PLCC package.....
29c256: cost is ~$5.xx for 1 now.
or if you make a 'switch' adapter, try the 29c512
and you could have 2 different 'tunes' on board.
cost is ~$2.15 for 1 now
all you uberdata, chrome, turbo edit folks are spoiled, what with all
the free tools you have....
Jeffrey Atwood
Old Nov 22, 2004 | 02:10 PM
Default Re: Atmel 29c256 Discontinued... (Jefnes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jefnes &raquo;</TD></TR><TR><TD CLASS="quote">
I REALLY like that idea
Old Nov 22, 2004 | 03:25 PM
omahaturbocivic's Avatar
This kinda sucks if you have the moates burner that only does like 3 chips.
Old Nov 22, 2004 | 05:57 PM
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jefnes &raquo;</TD></TR><TR><TD CLASS="quote">Buy an adapter and goto a 32PLCC package.....
Jeffrey Atwood
Jeffery Atwood- This is accomplished by flipping voltage on one of the pins, right? its gotta be a 5v source too, i'd imagine.
Old Nov 22, 2004 | 06:42 PM
2point2's Avatar
i have 6 chips :D long story...
Old Nov 22, 2004 | 06:43 PM
RMS's Avatar
RMS
we have 4-mem adapter boards in stock with c or sf chips included. our n20 board switches mem under programmed conditions on the fly...dyno'd 353whp on a daily driver with stock sleeves.
if your burner supports them the sf family is excellent...and cheap at under $2ea. we've been using them for over a year.
Old Nov 22, 2004 | 06:48 PM
Syner-G-Racing LLC's Avatar
you can use a chip with more memory as long as it is the same carrier and a fairly fast bit rate....29C512-90.
Old Nov 23, 2004 | 02:45 PM
.::Lee::.'s Avatar
Default Re: Atmel 29c256 Discontinued... (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">damn that sucks.... hopefully i can get a couple chips. If not, hondata here i come i guess </TD></TR></TABLE>
Hmmm, am I missing something? How will switching to hondata help you out? It runs on the same 'hardware' as any freeware does.
We would all be equally screwed if there wasn't any other solution out there.
Old Nov 23, 2004 | 03:19 PM
Tchleung's Avatar
Atmel AT29c256 can stillb e found in stock everywhere.. just order a bunch. You can always reuuse them remember. I have bene reusing the same 2 for a whiel now I jsut keep erasing and re burning via on my Moattes Burn1
Old Nov 23, 2004 | 08:52 PM
why are you guys stressing. that carrier style will still be available, just not that memory size. the minimum memory requirements for storing a bin is 256. so you can use a 512 or higher...they just cost a buck more. so instead of the 29C256 you'll use the 29C512. as far as the speed 60-90 is what I would recommend.
Old Nov 23, 2004 | 09:11 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">so instead of the 29C256 you'll use the 29C512. as far as the speed 60-90 is what I would recommend. </TD></TR></TABLE>
preach brother!
Old Nov 23, 2004 | 09:43 PM
Default Re: (Built B16A)
