how many degrees will a thick head gasket throw off cam timing?
Old Nov 21, 2004 | 08:41 PM
Cyphear's Avatar
Default how many degrees will a thick head gasket throw off cam timing?
Thanks. im put on a really thick HG and now the car isn't starting, im wondering if they are related.
Old Nov 21, 2004 | 08:57 PM
GeeReg's Avatar
Default Re: how many degrees will a thick head gasket throw off cam timing? (Cyphear)
From what I've read, about every 0.012" (0.3048 mm) you mill the head, it will retard the timing 1 degree. So figure out how much thicker the HG is than stock, and it will be the opposite, for every 0.012" it's thicker, it will be advanced 1 degree. I'm not sure if this is just for B series though.
https://honda-tech.com/zerothread?id=275598
Old Nov 21, 2004 | 09:26 PM
Kamin's Avatar
not enough to affect the car not starting.
Old Nov 21, 2004 | 10:15 PM
3RdT's Avatar
Default Re: how many degrees will a thick head gasket throw off cam timing? (Kamin)
sorry not to jack your thread or ne thing but does ne one happen kno for a d16?
Old Nov 22, 2004 | 12:52 AM
Cyphear's Avatar
im guessing it will be similar.
this puts me at about 5 or 6 degrees that my timing is advanced.
Thanks GeeReg. are you pretty sure that milling retards and thicker HG advances?
Old Nov 22, 2004 | 03:12 AM
GeeReg's Avatar
Default Re: (Cyphear)
It looks that way. If you search for "milling timing" in the archives you'll get a few posts about it.
drmix
May 27, 2008 09:25 PM
rol1in0n20s
Nov 25, 2007 08:27 AM
donnjuan2point2
Mar 11, 2004 01:59 PM
J T*
Jul 2, 2002 04:27 PM
Rob :190:
Apr 17, 2002 08:18 PM
