adjusting headlamps
Old Nov 21, 2004 | 08:09 PM
lilbluturtle34's Avatar
Default adjusting headlamps
where do u adjust the headlights on 94 integra plus i have hid should i aim it low high the middle?
Old Nov 21, 2004 | 08:29 PM
jonnyk80's Avatar
Default Re: adjusting headlamps (lilbluturtle34)
get some springs....... that should make the proper adjustment
Old Nov 21, 2004 | 09:11 PM
..::91TEG-G2::..'s Avatar
Default Re: adjusting headlamps (jonnyk80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnyk80 &raquo;</TD></TR><TR><TD CLASS="quote">get some springs....... that should make the proper adjustment
he's asking how to aim his headlights, not what does he use to lower his car..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilbluturtle34 &raquo;</TD></TR><TR><TD CLASS="quote">where do u adjust the headlights on 94 integra plus i have hid should i aim it low high the middle?</TD></TR></TABLE>
aim then like 2 inches below your knee with ur car 20/25ft away from a white wall (or any bright color if u cant find white) on a flat surface/ground.
go to http://www.team-integra.net and you can find a write up on it
Old Nov 21, 2004 | 09:12 PM
and i dont know exactly where, cuz i drive a G2.. bump for some help
Old Nov 22, 2004 | 06:26 AM
juicy.fn's Avatar
ok first ur question doesnt make sense, well it does but im not sure what ur asking. are you asking how do you aim ur headlights or where should u aim ur headlights.
well there are two aiming bolts in the back of the headlight assembly. look in ur manual and it should tell you how to properly adjust ur headlights.
second follow these procedures and it should help u prorperly adjust http://www.autooptiks.com/aiming.html
what kind of HIDs are u using, cuz if you have the plug n plays, then it should just aim like ur stock, but if you have a retrofit, then it might be harder to aim if you damaged the aiming bolts during the retrofit
bayareacivic
Nov 8, 2008 03:15 PM
Slump_Jay
Feb 20, 2008 08:58 PM
sole
33
Mar 18, 2006 12:31 PM
DrewQ1
May 11, 2004 10:47 AM
youngwon22
12
Apr 11, 2004 04:25 PM
