installing a viper alarm with remote start allready searched
do you htink this will be very hard ?? i have electrical skills somewhat and i have alot of car knowledge allthough dont claim to know it all but anyways.. thanks for some answers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darren90teg »</TD></TR><TR><TD CLASS="quote">do you htink this will be very hard ?? i have electrical skills somewhat and i have alot of car knowledge allthough dont claim to know it all but anyways.. thanks for some answers </TD></TR></TABLE> Not hard, get wireing help here.www.bulldogsecurity.com or http://www.streetdreams.com
94
94
after you get all your wire colors down, start your bench work.
Lay out the brain, plug in the harnesses. Depending on the location of the mount for the alarm module, cut back any unneeded wires, and zip tie or electrical tape your wires going to the ignition harness etc.
this will help in making a clean installation. also, soldier any 12v and ground wires together at the brain, then proceed with the install.
Pretty simple to install, just need to have a bit writer to make programming easy and put alot of time into making it look clean. I hate wires...
oh, and if you take pics or plan on running anything into the fuse box, i will shoot you.
so all the wires u have to solder is the 12volts and the ground? i watched that remote start installation video on bulldog.com and they say not to solder, crimp, or clamp any wires. they just tap into it and tape it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tca0bell »</TD></TR><TR><TD CLASS="quote">so all the wires u have to solder is the 12volts and the ground? i watched that remote start installation video on bulldog.com and they say not to solder, crimp, or clamp any wires. they just tap into it and tape it up.</TD></TR></TABLE> You can get away weth that, but, the best way is to solder all the connections, and every wire that you have to tag into has a plug someplace, and in that plug the wire has a metal "pin" of somekind, that can be removed from plug and alarm wire can be soldered to it, and then reinstalled into plug, [ easy and clean] then if you have to remove it, Honda wouldn't know that anything had ever been installed, [ also very easy to remove without leaving a mess.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">and every wire that you have to tag into has a plug someplace, and in that plug the wire has a metal "pin" of somekind, that can be removed from plug and alarm wire can be soldered to it, and then reinstalled into plug</TD></TR></TABLE>
im going to need a picture or something because i cant picture this in my head ahha.
im going to need a picture or something because i cant picture this in my head ahha.</TD></TR></TABLE>I am sorry I can't post pix yet, but will try to explain.
I will use the ign. harness as an example, if you follow the harness from the ign. switch, down and over to the fuse box, [it will split into 2 or more harnesses] that end in plugs that plug into the fuse box or into other plugs around fuse box, if you unplug them it will be easy to see how to depin them, [remove the metal termenal out of the plastic plug, (one at a time)] then, [what I do] "open" one of the "clamps" that is wrapped around the insulation of the wire at the "top" of the term. use the "clamp" to hold the starter wire to the side of the term. then solder, be carefull not to interfear with the area on the term. that holds the term. into the plastic plug, on smaller term, [low current like doortrigger or doorlocks] you don't need to "clamp" just solder to the metal term. I hope this helps
94
94
okay i have a better vision of this. my new alarm w/ autostart is coming tomrrow and im gonna attempt to install it myself.
hondaStarter
15
Oct 25, 2009 05:02 PM
neozero999
Audio / Security / Video
Jun 5, 2008 07:17 PM
