Running OBD0... how the hell do i wire OBD1 injectors
Old Nov 21, 2004 | 05:32 PM
shauniewalnuts's Avatar
Default Running OBD0... how the hell do i wire OBD1 injectors
Ok first off i searched and all the posts confused the hell out of me.
I am running OBD0 and dont plan on switching everything over to obd1, I have the mpfi swap done already. I am doing a mini me swap with a z6 head. what do i do about the injectors? i no longer have the obd0 ones anyway i plan on upgrading later to about 700cc and most aftermarkets are obd1. now do i just take out the resistor box? or keep it in or do i just get the odb1 clips and solder then in place of the obd0 ones?
Thanks Shaun
Old Nov 21, 2004 | 05:54 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Running OBD0... how the hell do i wire OBD1 injectors (shaun311)
if you can get obd1 clips get them, and solder them on. And yes all you do is remove the resistor box, and solder the wires together. obd1 injectors dont need a resistor, they are saturated, and the obd0 are peak and hold.
manny
Modified by mannyman at 3:10 AM 11/22/2004
Modified by mannyman at 3:12 AM 11/22/2004
Old Nov 21, 2004 | 06:02 PM
HamiltonRex's Avatar
Default Re: Running OBD0... how the hell do i wire OBD1 injectors (mannyman)
1: remove old injectors
2: insert new injectors
3: cut off old clips
4: solder on new clips (injector wiring plugs)
5: go to reistor box.
6: cut ALL the wires going into the box on both sides
7: solder them all together. (yeah it can be a mess)
8: you are done.
-Eric
Old Nov 21, 2004 | 06:41 PM
Default Re: Running OBD0... how the hell do i wire OBD1 injectors (HamiltonRex)
ok thank you!
Old Nov 22, 2004 | 07:15 PM
krazie1's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">1: remove old injectors
8: you are done.
-Eric</TD></TR></TABLE>
great that was my answer also and the way I did it
beansandrice
33
Sep 8, 2009 04:18 PM
e jay one
Sep 10, 2005 09:15 AM
civicefdx
Oct 24, 2004 03:25 PM
kur0ryu
Apr 26, 2004 05:05 PM
MidoriEK4
Apr 27, 2003 09:49 PM
