Axles from NAPA good or bad?
Old Nov 21, 2004 | 04:22 PM
SD1222's Avatar
Default Axles from NAPA good or bad?
i have a 94 hatch with a 95 LS motor and my axles are goin bad both driver and passenger side so i was looking for some new axles. At first i was looking towards getting new acura oem axles but the price is a lil too much for me so i found some after market axles from Napa. My question is have any of u guys bought axles or any major car parts from Napa and is it good? The axles their selling is about $100 for some brand new ones. Any help would be good. Thanks
Old Nov 21, 2004 | 04:26 PM
hayabusa160's Avatar
Default Re: Axles from NAPA good or bad? (jdm_spoonEG)
i got a napa axle works good
lifetime warrenty too hell yea
Old Nov 21, 2004 | 04:28 PM
SD1222's Avatar
Default Re: Axles from NAPA good or bad? (hayabusa160)
cool. Im going there tomorrow to get it so hopefully it'll work fine for me too.
Old Nov 21, 2004 | 04:38 PM
Archidictus's Avatar
Unceasing Measure
They always work fine for me too .
Old Nov 21, 2004 | 04:51 PM
intezn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">i got a napa axle works good
lifetime warrenty too hell yea</TD></TR></TABLE>
same here
Old Nov 21, 2004 | 05:20 PM
jde_07's Avatar
I went to checker but I'm sure they get them from the same place and I have never had any problem with my type r ones
Old Nov 24, 2004 | 07:53 PM
SD1222's Avatar
Default Re: Axles from NAPA good or bad? (jde_07)
okay i just replaced both the driver/passenger side axles today. When im on 1st gear letting go of the clutch and hittin the gas my car still vibrates .. not as big as before but the dashboard still shakes and vibrate. Is this common with swap motor? The motor doesnt shake or rock when u push it or anything like that or do i just need to let the axle break in?
Old Nov 24, 2004 | 08:01 PM
CivicEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_spoonEG &raquo;</TD></TR><TR><TD CLASS="quote">okay i just replaced both the driver/passenger side axles today. When im on 1st gear letting go of the clutch and hittin the gas my car still vibrates .. not as big as before but the dashboard still shakes and vibrate. Is this common with swap motor? The motor doesnt shake or rock when u push it or anything like that or do i just need to let the axle break in? </TD></TR></TABLE>
I think you need to learn how to driving a manual car a little more...
Old Nov 24, 2004 | 08:04 PM
HATCHingMN's Avatar
same here
Old Nov 24, 2004 | 08:19 PM
4potnick's Avatar
Default Re: Axles from NAPA good or bad? (HATCHingMN)
autozone, napa, and discount/advance auto aprts all use the same reman for axles. The part #'s are the same. I know this at least for 88-91 civic and 90-93 integra.
Old Nov 24, 2004 | 08:31 PM
POE's Avatar
POE
maybe a motor mount is fuked, idunno free bump
Old Nov 24, 2004 | 09:24 PM
xZeler8's Avatar
Default Re: (Vtecin94dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">maybe a motor mount is fuked, idunno free bump</TD></TR></TABLE>
or loose
Old Nov 24, 2004 | 09:25 PM
SOHC4life 96's Avatar
I agree. If it shakes when you accelerate from a stop(but is fine at cruising speeds), then chances are it is a broken motor mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I think you need to learn how to driving a manual car a little more...</TD></TR></TABLE>
Sadly this could also be the culprit.
Old Nov 24, 2004 | 09:42 PM
skunkwhat's Avatar
Default Re: (DOHC4life)
i bought a napa and it vibrated, took it back the next day.
Old Nov 25, 2004 | 07:01 AM
SD1222's Avatar
Default Re: (skunkwhat)
if one of my motor mount is loose or broken the motor will rock when u push it right? cuz the motor sit still it doesnt rock or anything even when i put my feet up agaisnt it and try to see if the motor is in good or not. As for the driving how does my car vibrating have to do with me learning how to drive stick? I said it vibrates letting go on 1st i didnt say the car bobs like when u first learn how to drive a stick car. I've been driving a stick for 5 years now. so i know its not that.
Old Nov 25, 2004 | 07:13 AM
TGrant's Avatar
if they are lifetime warranty then go with them because you can do cv's in about 40 minutes
just keep replacing them
Old Nov 25, 2004 | 08:42 AM
POE's Avatar
POE
did u say u try to push the motor around inside the engine bay? using your feet also? u wont be able to simulate the car moving at 7000 rpm, im sorry
Old Nov 25, 2004 | 08:59 AM
WyteNyteGSR's Avatar
hey i just got a bunch of things from napa yesterday....im just saying if your going to go through napa...fill out a form for a customer preffered napa card.....you can use it that day...AND YOU GET 30% OFF OF EVERYTHING PURCHASED FROM NAPA!!!!!!...
Old Nov 25, 2004 | 09:24 AM
Smith Wise's Avatar
Default Re: (jdm_spoonEG)
please stop kicking your motor
Old Nov 25, 2004 | 09:36 AM
SD1222's Avatar
Default Re: (Smith Wise)
im not kicking the motor like that what im trying to say is u can tell if your motor is not sitting right or is not put in right just by lookin at it, if its sitting straight or if u push it and it rocks then u'll know that the mount is not good.
Old Nov 25, 2004 | 10:39 AM
CivicHatchback14's Avatar
did Napa end up replacing your axles for free?
Old Nov 25, 2004 | 05:41 PM
Default Re: (CivicHatchback14)
yea you really can't similate how much ur motor is moving by rocking it. i tried to move it hard as i could. i got poly mounts all around. me being stupid thinking there was about 1 inch from the fpr to the strut bar it will be fine. way to the track gess what the **** smashed in to the damn bar hahahah after a hard 1-2 shift
rzstr
Honda Civic (2001 - 2005)
15
Oct 31, 2011 07:42 PM
devious
Mar 29, 2010 12:40 PM
BlUeHoOdCiViC99
12
Dec 24, 2005 12:38 PM
Rocks
Jun 28, 2004 02:25 PM
jdmskin
Oct 15, 2003 09:16 AM
