Integra 4-dr Suspension Noise
Old Nov 21, 2004 | 03:50 PM
supd_up's Avatar
Default Integra 4-dr Suspension Noise
Everytime I go over a bump, or if the road is bumpy, I notice a squeak. Anyone have the same problem? It is much more noticable after it rains.
Old Nov 21, 2004 | 04:59 PM
SlipAngleX's Avatar
i've noticed it when i have a passengers. I just had concluded that it was junk I had in the trunk... but come to think about it, I have done the ITR rear sway mod. And it hits the brake line that runs across the rear trailing arm :X eek...
Old Nov 21, 2004 | 05:56 PM
skunk2eg's Avatar
Default Re: Integra 4-dr Suspension Noise (supd_up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supd_up &raquo;</TD></TR><TR><TD CLASS="quote">Everytime I go over a bump, or if the road is bumpy, I notice a squeak. Anyone have the same problem? It is much more noticable after it rains. </TD></TR></TABLE>
how old are the shocks/struts?
Old Nov 21, 2004 | 06:36 PM
cogluve's Avatar
if u have lowering springs without rubber sheets wraped around the upper coils like tein springs than the squeaking prolly come from coil contact during compression. it also could be the rear sway bar (if you have upgraded to a thicker one)
Old Nov 21, 2004 | 07:31 PM
supd_up's Avatar
Default Re: Integra 4-dr Suspension Noise (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">
how old are the shocks/struts?</TD></TR></TABLE>
It made the noise before I swapped them out for the tokico blue struts and springs combo. It got a little better, but the noise was still there. That was about a year ago and now its starting to get as bad. Ne one had any bad experiences w/ tokicos?
Old Nov 21, 2004 | 07:33 PM
supd_up's Avatar
Default Re: Integra 4-dr Suspension Noise (cogluve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cogluve &raquo;</TD></TR><TR><TD CLASS="quote">if u have lowering springs without rubber sheets wraped around the upper coils
I used the same rubber sheets from the stock set up. Does that make any difference?
Old Nov 21, 2004 | 08:03 PM
B18C5er's Avatar
my guess is, it's the suspension bushings.
Old Nov 21, 2004 | 08:46 PM
cogluve's Avatar
I dont think the stock springs came with the rubber sheets. just to clarify stuff, this is a link to a pix of Tein S-Tech on classified forum:
https://honda-tech.com/zerothread?id=977579
(notice the black rubber sheets around the coils, thats the one im talking about)
im rollin on tokico illuminas with eibach sportlines(no rubber sheets) and a 22mm progress rear sway bar. The car also squeaks in the back everytime i go over a bump.
My friend's civic with gc coilover and same sway bar also squeaks when going over a bump. I think it could be the sway bar also. So if you have one, you might wanna check the sway bar bushings for lubrications.
mouab18c1
Nov 15, 2012 11:25 AM
xTimmyx
Apr 21, 2008 11:57 AM
Charbon Sty
May 7, 2005 09:34 PM
Thirty-Nine
17
Jul 8, 2003 08:11 AM
kek-san
Jan 2, 2003 09:17 PM
