Oil / Head - air pressure ?
Old Nov 21, 2004 | 02:27 PM
alotawatts's Avatar
Default Oil / Head - air pressure ?
I took off my oil filler cap (D16Y8) while the car was idling and noticed alot of air pressure. With all my other cars there is not much pressure and you can add oil at idle. Is this pressure normal for a Civic and other Hondas ?
Old Nov 21, 2004 | 05:01 PM
civictildeath's Avatar
Default Re: Oil / Head - air pressure ? (alotawatts)
i dont know if there is suppose to be pressure but if it is running when you open it you will get oil droplets everywhere just turn the car off before you open it
Old Nov 21, 2004 | 05:08 PM
BauleyCivic's Avatar
Risky Business
Default Re: Oil / Head - air pressure ? (civictildeath)
Crankcase pressure y0!
There shouldn't be one, most honda motors come stock with a PCV valve...
Old Nov 21, 2004 | 05:37 PM
alotawatts's Avatar
So my PCV may be plugged ? I'm talking (at idle) about enough air flow out of the oil filler hole to probably blow any oil you try and pour in back at ya'. Almost a howl of air.
If the PCV is clogged I'd have an MIL / Code would'nt I ?
Modified by alotawatts at 6:47 PM 11/21/2004
Looneytunerz
Nov 2, 2012 12:57 PM
lude98SH
Jul 15, 2008 04:18 PM
on2wheels
Jan 25, 2008 06:39 PM
Tage Evanson
12
Jul 22, 2005 09:24 PM
Smoothy
Dec 14, 2001 10:54 AM
