help... Eg stalling
Old Nov 21, 2004 | 02:06 PM
.Rex's Avatar
Default help... Eg stalling
i have a 92 civic SOHC non-vtec.... it has around 116k miles on it and runs great. I was at my friends house and had just turned off the motor. I had to move it like 2 minutes later, and i go to turn it on.. it turns on.. sputters then stalls out... i try 2 more times with it in neutral and my clutch is all the way down... it keeps stallling... so i put it in first gear and start it and it starts fine. This incodent has happened to me only once before about 2 months ago. I always park it in neutral. Why would this sputtering and stalling be?? im thinking spark plugs but why would tihs only happen once in a great while?? help pls
Old Nov 22, 2004 | 09:10 AM
ugot8up's Avatar
Default Re: help... Eg stalling (CarbonCivic)
from the sound of your name it looks to me thats whats in your motor...carbon...and lots of it...jk...try using some seafoam to clear out some of the crap thats in your engine...also give it a tune up...you can buy seafoam at any napa auto parts store or auto zone...follow directions exactly
Old Nov 23, 2004 | 01:38 PM
.Rex's Avatar
Default Re: help... Eg stalling (ugot8up)
ok thanks ugot8.... i went to napa and looked at the seafoam and i will be seafoaming it after this break.. it has been tuned up.. it always has been.. so we will hope that the seafoam works.. but if it doesnt it will still make my car run better
Old Nov 23, 2004 | 01:50 PM
lohatch's Avatar
pull your plugs and check them out. a set of plugs is like $8. you could also look into replacing your fuel filter which is about $30. these things are regular maintnance and certainly arent going to negetively affect your car.
Old Nov 25, 2004 | 03:49 PM
.Rex's Avatar
Default Re: help... Eg stalling (lohatch)
sounds good thanks.. hopefully it doesnt sputter and stall again
fuk_its_migz
Aug 22, 2014 04:50 PM
Gouki133
Apr 22, 2007 07:54 PM
All Motor EH2
10
Mar 1, 2005 10:37 AM
